Old 12-25-2014, 08:44 PM   #1
papaoso   papaoso is offline
whirring noise zongshen 250
Hello people, I own the ZS250GS and got a noise at the motor like something loose inside. it sound hardest in idle and cold, otherwise i noticed that the camshaft has some signs of wear, because I can not adjust properly the valves, so I thing the anterior owner run the bike w/ out oil.
wen I bought they have not the noise, (or only a little), and wen I changed the oil, it was full of an sustance brown like wood flour or something.
Well, I am not afraid to open the engine and check, but I thing is bad idea because......Were can I find parts.
The question is, can I replace the engine for other similar in size with some adaptations?
Or can I found engine parts somewhere?
Help me please.
Old 12-25-2014, 09:56 PM   #2
humanbeing's Avatar
It's based on Yammie. If u had plenty $ to burn, genuine Y... parts may work.
taobao.com + agent seems the most sensible way.
One of them:
http://item.taobao.com/item.htm?id=3469913830
Old 12-25-2014, 10:07 PM   #3
pete   pete is offline
pete's Avatar
Whirring noise........ could be the turbine starting up....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-25-2014, 10:11 PM   #4
I hardly try to find motor parts at taobao just in case, but...I don't Know how.
Sorry.
Old 12-25-2014, 10:14 PM   #5
Well, sound like randomly grinding something, but, don't affect the working of the motor. in fact run very good.
Old 12-25-2014, 10:17 PM   #6
any ideas about put an alternative engine?
Is good idea open it to see what's happen?
Old 12-25-2014, 10:32 PM   #7
Is my first bike in 30 years, I bought it cheap ($300.00) with the tank full . and I spend $200.00 more replacing back shock (used), brake cylinder, spray paint, ignition coil and some durabond.
I really enjoy this project, but I am a little worry about this noise, is not good. I really want to find any relatively easy solution, but I start to loos my illusion at this project. Well, still having some hope.
There some pics.
Old 12-25-2014, 11:03 PM   #8
Here the noise.
Old 12-25-2014, 11:19 PM   #9
Originally Posted by papaoso View Post
No, I don't have plenty of money. What you mind with Yamie?
Maybe's better forget the bike at the garage and try to save money in the future buy a real one Bike?
He means Yamaha. The engine is very similar to the Yamaha XT225, the TT-R230 and the TW200.
When you changed the oil, did you clean the oil filter in the side of the engine? The filter must go back in correctly, or no oil will get to the camshaft.
Old 12-26-2014, 12:00 AM   #10
Yes, the head look oiled, but the sound come mostly from the bottom.
Old 12-26-2014, 09:09 AM   #11
I see some affordable Lifan 200cc motors at EBAY.
Are compatible?
Can I swap w some adapt?
Were can I find specs, measures?
Thanks.
Old 12-26-2014, 12:47 PM   #12
Are compatible?
Thanks.
The Lifan motors on eBay are designed to fit a Honda application. You might be able to make one fit, but it will not be simple.
Where do you live?
Old 12-26-2014, 08:11 PM   #13
Where do you live?
South Florida.
Do you know any Supplier close?
Old 12-27-2014, 02:18 PM   #14
I believe there was a supplier in Florida, but I think they've closed the shop.
Taobao is a source for parts, as Humanbeing indicated. Use Google Chrome, visit www.taobao.com and allow Chrome to translate automatically. Search for ZS250GS, and see what appears.
Old 12-27-2014, 03:58 PM   #15
whata page taobao! that sacarry me
But I thing I can manage it.
I translated from english (well, from Spanish to English first) and to Chinese w google and c/ paste at taobao....and it works. i suppose That the agent in china is other steep, and the delivery time too. But I gona open the motor to see what's wrong, and send you some pics.
motor, noise, parts., zongshen250
