12-07-2014, 05:17 AM | #1 |
cg200 waterpump gear
Have had cooling problems .fan stopped .engine popping at high rpm .water use . overflow tank venting continuously .radiator leak checked and fixed.new electric fan . removed water pump cover and found that there was no resistance , so pulled side off engine. Nothing major 13 screws clutch cable foot well ,peg and other crap ,got to the guts and found inner gear stripped , so deciding whether to fix this up or just get a new motor , this still runs fine but I am concerned that the heat may cause some issues later on ,plus how and where to find water pump gear cheap enuf
12-07-2014, 06:19 AM | #2 |
12-07-2014, 05:43 PM | #3 |
Cheers but that site is in Chinese , wondering if I should just put it back together without the pump and see what happens
12-07-2014, 11:57 PM | #4 | |
never figgered out why they cool a motor.... just extra weight..
12-08-2014, 12:06 AM | #5 |
I suspect that it'll struggle without the cooling system, since there are no cooling fins on that cylinder. You could certainly convert it to air cooled.
12-08-2014, 11:16 AM | #6 |
Water pump
You can try CHINAPARTSDEPOT in Vancouver... Check their site on the web for ph#.. he has parts for everything... major parts supplier
12-08-2014, 04:34 PM | #7 |
Thanks flash I,all try them , I,m having no luck finding a replacement gear on the net , and there definitely won't be any here in tasmania ,can u just buy a finned cylinder and make it air cooled (piston as well)
12-08-2014, 08:48 PM | #8 |
burge is in Australia. If can't find it locally, buy from China seems the LAST resort. OZ & parts: http://www.chinariders.net/showthread.php?t=10750 btw: taobao.com had official forwarder to OZ if READS chinese (NO agent NEEDed) Y85 (1st kg) + Y26 /.5 kg http://www.taobao.com/go/chn/transit...0.0.0.0.wYcn2v
12-09-2014, 04:28 AM | #9 |
Cheers HB
