Old 07-02-2014, 12:48 PM   #46
You are a lucky man to have such a pretty little helper.
Old 07-02-2014, 10:07 PM   #47
Dave_D   Dave_D is offline
Dave_D's Avatar
Thanks Spud.
I unbolted the shock today and tryed the test. It still turns a bit. But I have nothing to compare it too so not sure if or how much in improved. Pics below
Dave
Old 07-03-2014, 01:12 AM   #48
Dave, that strikes me as solved.
I doubt that you'll ever get that much articulation out of the front suspension, and I bet the front wheels don't turn at all within the range of the shocks.
Old 07-03-2014, 01:15 AM   #49
Dave_D's Avatar
I'll still report back after first ride. Should know right away
Dave
Old 07-20-2014, 03:01 AM   #50
Dave_D's Avatar
We finally took it for a ride today. Sorry for the delay
I spent quite a bit of time on it and I didn't feel or notice any bump steer
Wife says its 100 times better to and didn't feel it either.
Dave
Old 07-20-2014, 09:51 AM   #51
Thanks for the update.
Old 07-21-2014, 01:45 AM   #52
That's awesome! I'm definitely doing the "Dave D" mod to my 150.
Dave, if you create another post that just contains that specific mod, I'll add it to the ATV sticky. It's good info to pass along.
Old 07-22-2014, 01:51 AM   #53
Dave_D's Avatar
Will do. I'll start putting a step by step together and post it once I'm done
Dave
Old 07-31-2014, 11:28 PM   #54
Dave_D's Avatar
Been a while since I posted something about my china atv
So here goes
The tires I swapped onto the quad one of the rears had a broken valve stem
So I sent it to my brothers (he has access to a tire machine) and he swapped it out for me.
Today I was putting the tire back on and noticed something on the exhaust behind the fender
Closer
I fired it up and can't feel it leaking from the crack. I might weld it up I might leave it.
Or il just use exhaust off the parts quad.
I've also been fighting with the wires on the back of the ignition have to wiggle and bend them to get starter to engage.
Might order this up rather then try and fix
Price seems good lol
Dave
Old 07-31-2014, 11:49 PM   #55
I'd weld it up.
I installed tubes in my Beast to get rid of poor beads. Cheap and easy.
Old 08-01-2014, 12:44 AM   #56
Dave_D's Avatar
I'd weld it up.
On my quads in past I run the tire till it's got like 5-6 plugs. Then give up and tube lol
Yea probably quickest and simplest repair.
My link never posted in last post
http://www.ebay.com/itm/221299578383
Looks plug and play for this application
Dave
Old 08-01-2014, 01:39 AM   #57
It might be, although I bought one that was wrong. NBD. Just carefully remove the terminals and correct them.
I installed tubes because I couldn't ride around the yard without popping a bead, and that was despite trying several different tire pressures.
Old 08-01-2014, 10:48 AM   #58
Dave_D's Avatar
That's a great idea. I completely over looked that idea
I have a 4 wire ignition I took off the xr80 I'll just use then
Thanks
Dave
Old 08-10-2014, 01:04 PM   #59
Dave_D's Avatar
As mentioned in my other posts. We took a bunch of toys out yesterday including the quad.
When we were leaving I tryed to ride the quad up the ramp into my truck. It couldn't do it. Truck was on flat ground
I load it this way at home all the time but our driveway slops down and our culdesac is level so I park truck on road and ramp goes onto driveway so the ramp is not steep at all
My question are they normaly this gutless or should I be fixing something
Cruising the loging roads it feels like it has great power
Thanks
Dave
Old 08-10-2014, 03:52 PM   #60
It's a lot to ask of a 150cc CVT to carry a full grown man up a ramp into a truck. I push mine.
