VM26 Carb Needle Removal & Needle Position
So I am in the process of installing my new Mikuni VM26 carb on my stock Hawk 250 and have run into an obstacle that I am unable to find an answer to. I have jetted the main jet (to a 110) & the pilot jet (to a 25) and have proceeded to adjust the needle clip position but am unable to figure out how to remove the VM26's spring seat plate to allow me to get to the needle for removal. When looking at the stock carb which I just removed, I can easily see how to remove the needle from the stock carb but this new VM26 carb is different and I cannot figure out the method of removing this plate that is on top of the needle clip. Does anyone know how this plate over the needle and clip may be removed??
Also, my intention is to place the needle clip of my new VM26 carb to the "center" position as recommended, and so does anyone know what needle position these new VM26 carbs come with from the factory? For all I know, the carb may have the needle in the center position right from the factory, and if so, then that would be great because the carb would then be ready for install. But this needle clip plate is the only thing standing in my way right now for installing this new carb. Anyone able to help? Thanks! |
Picture looking down to plate?
2006 roketa 200cc 1971 Yamaha xs650 2x 1980 xs650, 1 is a café, other is a chopper/brat 1972 Honda xl250 2x early 90's Honda rf600 parts bikes more mc junk laying around. ![]() |
I am working on photos, but for now it is #6 in the exploded drawing at this web link:
https://www.jetsrus.com/carburetor/c...iew_parts.html Thanks. Hoping to have pics uploaded soon. |
#4 | |
But in the meantime, this is a carb for which many Hawk owners recommend and so there has to be someone here who has done this install and can help. Thanks! |
have struck that before with a few carbs...
the plate is slightly to big in dia and gets wedged in the slide... get a thin screw driver though the cable slot & prise it out... then file the edge so it's free before you put it back togeather... If it gets stuck before it gets to the bottom of the slide it can let the needle float......that dosn't make carb tuning any easyer... ..
I figured it out! It came out when I applied pressure to the needle. It was a tight fit but I came across a Mikuni carb disassembly video and seen that it should just come out easily. Mine took a little bit of force to remove but its out!
Hooray!! |
Thats exactly what the deal was! Thanks Pete!!!
Display Modes | |
