05-25-2017, 07:37 PM | #1 |
RPS 250 magician upgrade
Hey guys. This is my first post.
So I've upgraded to a 17t front sprocket, and have rejetted my stock carb to a 110. Is there anything I can do to my exhaust and/or air box to compliment my new carb jet? I'd prefer not to buy anything new, I'd rather modify the stock exhaust in any way I can. Thanks! |
05-26-2017, 01:38 PM | #2 |
I gutted the cat and removed the spark arrestor on my Magician and it sounds pretty good. There is thread on here about gutting the cat by jerryhawk. You may need a 115 and a shim under the needle afterwards.
05-26-2017, 01:47 PM | #3 |
05-29-2017, 10:59 PM | #4 |
Is 115 the biggest I should go? I opened my intake a little bit and I gutted my cat. As for shimming, I need to do some research, I know nothing about that.
05-30-2017, 06:58 PM | #5 |
You may need larger than a 115. I only said that because its what I have, but elevation plays a key role in that so to know for sure you'd have to do a plug chop. It was only a jumping off point. And shimming the needle means to put a small washer or two between the slide valve and the retaining clip for the needle. Basically it just moves the needle up allowing more fuel for 1/4 to 3/4 throttle. But with anything its trial and error. These are just recommendations of what has worked for others.
Tags |
magician 250cc |
Display Modes | |
