Old 09-25-2014, 01:30 AM   #121
pete   pete is offline
pete's Avatar
Originally Posted by Dave_D View Post
Excellent idea weld. I'll check tgat before installing it.
Pete. From my reaserch I'm pretty sure it's a mikuni bst34
Dave
34?.... the TTR250 has a 30mm...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 09-25-2014, 11:42 AM   #122
Dave_D   Dave_D is offline
Dave_D's Avatar
I swapped the jet out this morning before work.
So now it's 42.5 and 140
Not sure when we will get out for a ride next to see if it's good
I'll keep you posted
Dave
Old 09-26-2014, 01:17 AM   #123
I'm interested in the outcome. 140 strikes me as quite large for a 225.
Old 09-26-2014, 03:53 AM   #124
pete's Avatar
small pilot & large main
or
large pilot & small main...
The pilot jet dosn't stop feeding fuel
just because the main jet starts to work
it feeds fuel though the whole rev range..
It's the combined size of both jets at higher RPMs....
cold climate... large pilot/small main , easyer
starting / warm up..
Hot climate.... small pilot/large main...
Or anywhere in between...
my bikes prob a little bit rich on the bottom end..
the US TTR250 & my NZ one have diffrent jet combinations..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 09-26-2014, 10:11 AM   #125
Dave_D's Avatar
I rode the bike aroun the Parkinglot at work once it was swapped
But need to get it out somewhere and really ride it and see.
Hopefully soon. Doing a roof this weekend so probably not this weekend lol
The petcock is dripping again. It'll be getting swapped out shortly
Dave
Old 11-24-2014, 12:13 AM   #126
Dave_D's Avatar
Long time no post..
Inbetween renos and side projects. I finally moved my bikes to my new place.
Today I FINALLY got to doing the petcock
Not many pics. I was slacking on the documentation lol
Drained the gas
I was quite surprised how much fuel this bike holds almost filled that jerry can and the tank wasent even full all the way
Removed the stock petcock. And spotted a difference right away
The knob on the original one also wouldn't go onto the new one.
So. I opened them up
Insides were identical and looks like the original one was missing an o ring
I put the gaskets and o ring out of the new one into the old one. Put it all back together and onto the bike.
No leaks and seems to be working as it should. And fuel amount for "on" and "res" stayed the same
Plus I got to keep the knob
Dave
Old 11-24-2014, 12:36 AM   #127
Good work. Thanks for posting the update.
Old 11-24-2014, 10:50 AM   #128
Hey Dave, thanks for checking in!
The on and res tubes were backwards in your replacement, just like mine. Whomever is assembling them has no idea.
Good call on just replacing the parts, rather than the entire valve. I'm sure the Yamaha valve is a higher quality casting.
Old 12-27-2014, 02:00 AM   #129
Dave_D's Avatar
I finally ordered the oil filters I posted about ages ago
I ordered 2 of them. Prepping for next oil change. I'll do the filter at same time
http://pages.ebay.com/link/?nav=item...d=131074527625
I also ordered a uni filter. Always wanted a spare too and theses are supposed to flow more. We will see if there's a difference.
http://pages.ebay.com/link/?nav=item...d=111433959489
I'm also thinking I might plug the hole someone's drilled in the airbox lid and see what that's like
I've posted the photo before but here it is again
I think I'll plug it. Try it and if it seems restricted at all I'll remove the snorkel and see what that's like. I've read its a common mod on these bikes.
Dave
Old 12-27-2014, 02:26 PM   #130
I haven't modded the air box on my TW, but I've considered removing the snorkel.
Old 12-27-2014, 03:01 PM   #131
cheesy   cheesy is offline
cheesy's Avatar
You'll like the Uni. Probably hate the maintenance of it(I do), but you'll like the filter.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 12-28-2014, 12:55 AM   #132
Dave_D's Avatar
Also the jetting issue was never 100% cured still a little on the lean side.
Ive ordered 2 more jets to try...
145 main and a
150 main
We will wait and see what happens. Seems rather large. But who knows
Dave
Old 12-31-2014, 11:49 AM   #133
Like Pete says, it depends on the slow jet size. I'll be interested to find out if a jet as large as 145 is needed.
Old 12-31-2014, 12:59 PM   #134
Dave_D's Avatar
I thought that. But it's loosing all power at full throttle
Plus white plug so I assumed main jet
Could be wrong though
Dave
Old 12-31-2014, 02:22 PM   #135
Dave
I hate to say it, but the problem might be electrical. Are you having any troubling starting the bike?
Search this Thread:
Advanced Search
Display Modes
