02-02-2017, 07:09 PM | #316 | |
Last edited by Ariel Red Hunter; 02-02-2017 at 07:17 PM. Reason: A miss spell-add more info |
02-02-2017, 08:12 PM | #317 |
x2 ARH... Pull up those forks. Clearance and stability will be better.
02-02-2017, 08:32 PM | #318 |
good picture of the bike. I kept the 15 and put the 40 on the rear. Fastest I got was 74 mph on the GPS. Good combo for on and off road. I only weigh 185.
02-02-2017, 09:00 PM | #319 |
To Skurdy
Let us know if re-adjusting the forks makes a difference.
02-02-2017, 09:36 PM | #320 |
Working on it as we speak actually! I also have email notifications on so if I forget just reply and I'll hop on here!
02-02-2017, 10:46 PM | #321 |
Adjusted the forks
Here's the forks I raised it up about to go test it out took me awhile cause I'm new to this but got it done
02-02-2017, 11:08 PM | #322 |
Update on forks: Success
Thank you guys huge improvement! I can see the road at night now and I sit up a lot higher and it's way smoother and more comfortable positioning for my back and the turning is better I haven't tested high speed yet but I will tomorrow in daylight when I can see way better! Thank you it's a huge improvement now I need the sprockets, carb and exhaust system, chain, spark plug! OH AND GUYS!! Question for all, what chain (count) like how many links, for 15t front and 40t back like can I use the default chain! Or what chain and link thanks for input!
02-03-2017, 06:37 AM | #323 | |
02-03-2017, 10:06 AM | #324 |
What did you do to remove two links??
02-03-2017, 10:24 AM | #325 |
If you haven't already, drop those forks down in the triple trees. They push the front down and slide the forks up in the trees for shipping.
02-03-2017, 11:00 AM | #326 |
I used a small grinder to grind down the pin then used a center punch. Or you can buy a chain breaker if you don't feel comfortable doing it. You can pick one up from tractor supply.
02-03-2017, 12:11 PM | #327 |
You know what? I wrote a response to Skurdy's problem yesterday, and the post has disapeared. Any body know why?
02-03-2017, 12:13 PM | #328 |
Yes I did I'm also gonna be testing the handling max speed today aswell! I uploaded a picture of the forks! Raised up and also gave some input if you refresh the page when you're here it'll reload everything and then you can see all the post (new ones)
02-03-2017, 12:13 PM | #329 |
No I seen it?? And fixed it like you said to do. And uploaded a response with a picture
02-03-2017, 12:16 PM | #330 |
Also thank you for letting know I'll probably just buy a chain breaker from tractor supply! I watched a video on it 😉
Display Modes | |
