03-16-2019, 08:28 AM | #16 | ||
03-16-2019, 08:45 AM | #17 |
Simple stuff first. Mine came with the wires hooked up to the front brake lever rather than the clutch. There is a safety system on it so the "clutch" has to be pulled in to start. Yours may also have a safety switch on the kick stand. I had to move the wires from the brake to the clutch lever. No big deal.
Check that stuff first.
2020 Kawasaki KLX300R, 2018 Yamaha TW200 If you want more of something, tax it less. If you want less of something, tax it more. |
03-16-2019, 08:52 AM | #18 | |
03-16-2019, 09:06 AM | #19 |
I bought an amazon battery, it barely has enough CCA to start the bike. try hooking it up to the battery charger and make sure it is 100% "topped off"
If my battery id not fully charged my bike will turn over but not start. Could also be a malfunction in the ignition switch? |
03-16-2019, 09:16 AM | #20 | ||
03-16-2019, 10:05 AM | #21 |
Try open and closing the gas tank,it may have an evaporative system like my venom bike did.when it sounded like that at cold start I’d open the tank then close it and it worked.check and make sure fuel is getting through,no kinked up fuel line or shitty fuel filter.id fill my gas all the way up too.
When I got my Apollo rfz I did everything on it and when I went to finally ride it wouldn’t start for sh*t.Pissed me off.Pulled it apart again only to get under the gas tank and clearly a plug had slipped out.I plugged it back up and VOILA,started right up even though I lost that day of riding by the time I found it but I felt way better.Good luck on your bike,I hope it gets figured out don’t kick it off the cliff yet. |
03-16-2019, 11:19 AM | #22 |
Could you take some close up pictures of your hand controls?
03-16-2019, 12:20 PM | #23 |
Not a bad idea. Better to be sure. Also since no spark is narrowed down, might be a good time to remove the gas tank so you can get access to some of the connecters and ignition coil. Start poking around and see it's getting power. Also get around that kill switch. I'm not expert by any means, but that's what I'd do.
03-16-2019, 12:35 PM | #24 |
You sound like a sucker for punishment ,having a hard time starting a simple bike like a hawk ,then jumping into an old multi cylinder no start Honda before figuring out the hawk .
I kinda like that ! |
03-16-2019, 12:44 PM | #25 |
I got the non-running Honda running in about 5 minutes. Popped in the new battery I bought for the Apollo...fired right up. If only this bike can be this easy.
03-16-2019, 12:56 PM | #26 |
I understand the frustration. I’m pretty good at bike electrics. It’s going to be something ‘simple’ and/or cheap to fix I think. Would be handy to have a volt meter and have the tank and seat off. My guess is, wires disconnected, or misconnected, or something else along those lines. If you want some help, I’d be glad to give you a phone call, maybe tomorrow, and walk you through the process as best I can? PM numbers etc, tho lol.
1988 Kawasaki KLR250 1969 Honda Z50 silver tag 2002 Ford F-350 7.3 diesel 1975 Corvette 2017 Chevy Bolt “Throttle twisting geek” -LFN |
03-16-2019, 01:52 PM | #27 |
Meanwhile, look at page 51 of this. Use your volt meter to make sure 12 volts is getting to the CDI when the key is on
http://therps.net/User%20Manual/Hawk...s%20Manual.pdf The pulse coil should have a reading too, when the engine is cranked. Also, the output to coil wire should also have a reading when cranked. Those are the basic checks to start...
03-16-2019, 02:28 PM | #28 |
I wouldn't give up just yet. You have it narrowed down to a no spark issue. A little circuit chasing and diagnosing with a multi-meter should sort this problem out much more quickly than you think.
03-16-2019, 04:08 PM | #29 |
If you don't mind me asking, where in the US to you live? Perhaps someone close to you could come over and give you a hand. There are quite a few people here that could probably get it running pretty quick.
03-16-2019, 04:14 PM | #30 |
I don’t mind at all. I live in the northeast corner of Nebraska, an hour west of Sioux City, iA. And, I will take all the help I can get!
Display Modes | |
