Old 06-15-2009, 08:43 PM   #1
805camaro   805camaro is offline
2 random disconected hoeses... -_- the fustration rolls on.
Well on taking off plastic and skid plates and chain gaurd.. i noticed a couple things that were odd..... hmm.. Well here you go you got a hose off of the air cleaner or where it looks to be from and then there is another one right off the engine
Also what would i have to replace here...
Old 06-15-2009, 11:37 PM   #2
katoranger's Avatar
I believe those two hoses are okay. They are vents. Should just be routed to the bottom of the bike.
It looks like you are missing the sprocket cover. As recommended in another thread you will need to just replace that chain.
I believe it is a 428 chain. Just take it off and bring it down to a bike shop. They can match it up.
Allen
Old 06-16-2009, 12:11 AM   #3
What about this little fitting its on the frame. Not sure what exactly it is but looks to be a macro line fitting not 100% sure. But will get a new chain and a new battery if i can find a new one in my area
93041 if anyone knows one near here
Old 06-16-2009, 12:34 AM   #4
katoranger is right on. The hose from the engine is a breather and the hose from the air box is a drain. You don't want water to fill up the airbox, and you definitely want crankcase pressure to find its way out through the hose. Both of those items are ok. Make sure that neither of them can get caught in the rear suspension.
Don't worry about the front sprocket cover. Most riders remove them to allow for easy mud removal. Just take care not to ride with wide leg jeans on. 8O
Not sure what you mean by "little fitting on the frame".
Keep the questions coming; we all start somewhere. 8)
Old 06-16-2009, 08:46 AM   #5
katoranger's Avatar
I think alot members have been able to find a battery at walmart. Just bring the old one in and match it up. They usually have a sheet the cross references them. You will need the old battery to avoid the core charge too.
Allen
Old 06-19-2009, 02:00 PM   #6
Reveeen   Reveeen is offline
From the looks of "things" it sure wouldn't hurt to route your crankcase breather into the vicinity of your chain.
Old 06-19-2009, 03:45 PM   #7
forchetto   forchetto is offline
LOL
The OP mentions "couple things that were odd..." meaning two odd breather hoses. Didn't think the chain rusted solid was odd....
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 06-19-2009, 04:35 PM   #8
TurboT   TurboT is offline
No chap that's normal for a garage kept bike. Mine always look like that.
Old 07-01-2009, 12:39 AM   #9
knothead   knothead is offline
LOL
That would have been his next post... "HELP! My back wheel won't turn!"
Seriously though, if he's anything like me he probably figured it was so obvious it didn't need mentioning..... I hope that was the case anyway.
Search this Thread:
Advanced Search
Display Modes
