04-16-2009, 03:15 PM | #31 |
Okay, decided to go with the pz30 for mine as well, just for grins lol
Was wondering if you could help me out by figuring out what jets to get for it, or where you got yours at (like the tried and true method of aftermarket tinkering) Thanks in advance |
06-11-2009, 11:04 PM | #32 |
Ok....so I think I may have stumbled upon a big bore kit for these motors. The piston size would increase from 67mm to 75mm. I believe that would near or top 300cc.
I need to know what engine our water cooled motor is a clone of. Anyone know?????? My motor is stamped 163ML |
06-12-2009, 09:46 AM | #33 |
I believe it's a lifan clone. Which is kinda weird because they don't have vertical 250cc engines (that I can find anyways) But this looks pretty close. Maybe someone can verify the measurements on the print there..
http://www.hooperimports.com/product.aspx?pf_id=E2005M After further web surfing I'm now convinced that these are actually 200cc engines... and man that makes me angry :x Can anyone confirm that they are or are not 250cc engines? Thanks
Vbike V4-SW 250cc |
06-12-2009, 08:32 PM | #34 | |
I did read the manual and for specs it shows a bore x stroke of 78mm X 61.2mm. It also says the compression ratio is 8.9:1 which is very low. The manual also says the engine is 239ml. The front tag on the ATV says 230cc, the book says 250! Please someone help. I need to know exactly whats up. |
06-13-2009, 02:30 PM | #35 |
When I put those numbers into a displacement calc it gives me 292cc.
Allen
06-13-2009, 11:44 PM | #36 | |
06-16-2009, 12:24 AM | #37 |
anyone have some info?
