05-03-2024, 05:41 PM | #211 |
rear brake switch installed. very easy to do. package came with two, one of which plugged right in and worked perfectly. also added the heavy duty mirrors..what an improvement!!! its coming together for this summer adventures.
2022 Hawk 250 |
05-04-2024, 01:38 AM | #212 | |
05-04-2024, 04:13 AM | #213 |
Same with my 700 4.6x18. I am running a 33t rear instead of a 35 to compensate or the smaller diameter. My effective gearing is now the same as the stock tire with a 35. I run a 520 chain setup, if you are curious. 13f and 35r is equivalent to a 17f and 45r with the 428 chain.
05-04-2024, 03:31 PM | #215 |
It gears you down about 2 teeth out back.
05-07-2024, 10:10 AM | #216 |
inexpensive mirrors and so much better than stock that its not even in the same ballpark. With these I can actually see behind me and didn't even put em on backwards! they hold their position too..far better than the ones I had which required constant adjustment.
2022 Hawk 250 |
05-14-2024, 09:24 AM | #218 |
This is the exact rear tire I bought and I am pretty sure it changed my gear ratio.
edit: according to microsoft copilot this changes my drive ratio by 5.4% which is comforting because I thought perhaps I'd lost my mind.
2022 Hawk 250 Last edited by Zapkin; 05-14-2024 at 10:13 AM. |
