Old 05-03-2024, 05:41 PM   #211
Zapkin   Zapkin is offline
Zapkin's Avatar
rear brake switch installed. very easy to do. package came with two, one of which plugged right in and worked perfectly. also added the heavy duty mirrors..what an improvement!!! its coming together for this summer adventures.
2022 Hawk 250
Old 05-04-2024, 01:38 AM   #212
Richie311   Richie311 is offline
The stock tire width is technically 4.33 inches wide, but the knobs on the tire make them physically wider. So you can use a 4.10 or a 4.60 width without issue and they are both functional. My Shinko 700 rear is a 4.6 x 18 and works perfectly, but looks narrower than the stock knobby tire too.
I just put some Shinko 244s on mine and did 4.6x18 in the rear and noticed them same thing. Over all it's narrower and shorter but I also put a 42t rear sprocket on so it worked out in the end.
Old 05-04-2024, 04:13 AM   #213
Same with my 700 4.6x18. I am running a 33t rear instead of a 35 to compensate or the smaller diameter. My effective gearing is now the same as the stock tire with a 35. I run a 520 chain setup, if you are curious. 13f and 35r is equivalent to a 17f and 45r with the 428 chain.
Old 05-04-2024, 11:23 AM   #214
Bill Hilly   Bill Hilly is online now
When I put the 4.60x18" Dunlop D605 on my Hawk, it geared me down just a hair. I had recently went from a 16 to a 17 tooth front sprocket, and the difference in the tire is noticable, but I can easily live with it.
Old 05-04-2024, 03:31 PM   #215
It gears you down about 2 teeth out back.
Old 05-07-2024, 10:10 AM   #216
Zapkin's Avatar
inexpensive mirrors and so much better than stock that its not even in the same ballpark. With these I can actually see behind me and didn't even put em on backwards! they hold their position too..far better than the ones I had which required constant adjustment.
2022 Hawk 250
Old 05-07-2024, 10:30 PM   #217
buzz   buzz is online now
ya it help tp put them on the right way,smoke a another one he he.
Old 05-14-2024, 09:24 AM   #218
Zapkin's Avatar
This is the exact rear tire I bought and I am pretty sure it changed my gear ratio.
edit: according to microsoft copilot this changes my drive ratio by 5.4% which is comforting because I thought perhaps I'd lost my mind.
2022 Hawk 250
Search this Thread:
Advanced Search
Display Modes
