04-22-2024, 10:46 AM | #1 |
What are these stock screws made out of aluminum? Every bolt is stripping
Like I'm at the club making it rain! I remember reading a post researching about a kit to replace every bolt for our bikes but I actually bought mine from the little dealer in Texas so it was already assembled. On the 2nd carb clean and I strip out the junk plastic throttle body spacer female threads just trying to tighten down the dang carb. I almost feel like epoxying the studds in
04-22-2024, 10:55 PM | #4 |
No problems on mine.
04-22-2024, 11:04 PM | #5 | |
04-22-2024, 11:07 PM | #6 | |
04-23-2024, 09:35 AM | #7 | |
Also get yourself a hand impact driver for maintenance. Works great for both Phillips and JIS (if you have the right bits). |
04-23-2024, 10:10 AM | #8 |
JIS screwdrivers
https://www.amazon.com/Screwdriver-J...RoCRw0QAvD_BwE |
04-23-2024, 12:58 PM | #9 |
An impact driver was one of the first tools I got to work on my used 1970s era Suzuki TS250 in 1976. It loosened, and then properly set the crankcase screws when I had to rebuild it. I didn't even replace the screws (what did I know!?), but it held together OK. It cost me $5, with four bits-2 flathead, two JIS/philips (no idea which). Essential tool
All six main bearings and seals on the ends of the crank, counter, and drive shafts, New second gear and counter shaft (fused together), full gasket kit, rebored cylinder (maybe 270cc) and new piston/rings. Oh, and an expansion chamber to replace the OEM muffler. Then I got the crash course in jetting. That impact driver is still useful.
04-23-2024, 02:14 PM | #10 | |
04-23-2024, 02:44 PM | #11 |
They're made of Chinesium.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come. |
04-23-2024, 03:05 PM | #12 | |
05-04-2024, 09:42 PM | #13 |
Soft as Butter Screws
You're right - Phillips head screws, especially the ones you have to remove a lot, like the side panel for the battery. The olive drab green color makes it look like the factory received a shipment of surplus screws from the Chinese Army. Hope they run out soon.
05-04-2024, 09:48 PM | #14 | ||
05-05-2024, 07:12 PM | #15 |
Aged Cheddar
Aged Cheddar - I'm dead
