06-25-2022, 04:14 PM | #1 |
Hawk 250 rear wheel spoke size
I know this has probably been asked on here before but without all of the extra nonsense, is anyone able to post a link to a site where I can buy spokes for a hawk 250 rear wheel? Please and thank you.
06-25-2022, 05:03 PM | #2 |
These work.
https://www.aliexpress.com/item/2251...apt=4itemAdapt From this thread. https://www.chinariders.net/showthre...rR0BW8hP9MBfNw If you need help searching things, instead of searching on the forum directly, which I have always had hit or miss luck with, search for it on google with chinariders.net at the end of your search query. I tend to find more results that way
06-26-2022, 12:58 AM | #3 |
Ouch, so I guess no luck going for a ride within the next 4 weeks bc of that delivery time?
07-02-2022, 06:51 PM | #4 |
Update
Found spokes that work on ebay. Not sure how long this link will work but here you guys go. https://www.ebay.com/itm/27479652598...kAAOSwHhVgnXXq
07-07-2023, 06:38 PM | #5 |
I'd rather not spend $30 on spokes, so I've decided to fabricate some. I know that the spokes are 4mm diameter, and around 6 inches long, so I've bought some solid steel rods that are 4mm in diameter. They arrive on 7/11/2023 and I'm going to use a die to put the right threads on the end, then I'll forge them into spokes with the head and bend. I'll let you all know how it goes. All else failing, I'll just bend the metal into hooks and hook it though the hubs, but I am going to try to fabricate spokes that are as close to original as possible.
07-07-2023, 09:26 PM | #6 | |
hawk, hawk250, spoke, spokes, wheel |
