03-06-2023, 03:06 PM | #1 |
Identify used engine?
Some of you already know I've been trying to get the 167FMM in my CCW Heist running with no luck.
In the meantime I've also been searching for a replacement engine just in case. Found one local on marketplace, but curious if it will be a direct bolt in or if there are any differences (all these things look to same to me lol). I figure it might be worthwhile if I can get it on the cheap |
03-06-2023, 05:22 PM | #2 |
How much,and is it a runner.C
03-06-2023, 05:23 PM | #3 |
Check compression!
03-06-2023, 05:28 PM | #4 |
Seller claims it came out of a running ATV, which already sounds shady (why pull it then?)
I'd definitely want to see it crank with my compression gauge before making an offer. |
03-06-2023, 06:07 PM | #5 |
If it came out of an ATV then it likely has 4 forward gears and a reverse.
03-06-2023, 06:27 PM | #6 |
as Mudflap suggested, if its from an ATV it likely has a reverse gear.
looks to be a 250cc. Has Zongshen branding on the case covers, but the engine serial number does not begin with ZS... ok for parts or an ATV/gokart transplant. |
