10-11-2022, 11:01 PM | #1 |
TBR7 valve clearance screw replacement ❓️❓️❓️
What's good guys. I been having a really hard time trying to find a replacement for my TBR7 rocker arm adjuster screw. I was trying to adjust trying valve clearance like most people recommend and while I was tightening the screw snapped in half. I have very High Hopes that someone can help me find the right replacement for the screw. Pls and Thank You.
10-12-2022, 09:27 AM | #2 |
Check with CSC. The TT250 should use the same Tappet Adjuster screw.
10-12-2022, 04:17 PM | #3 |
Alrighty I'll try them options out. Thank You
parts., replacement, tbr7, valve adjustment, valve clearance |
