04-28-2020, 04:08 PM | #346 |
Ok how much off
04-28-2020, 04:16 PM | #347 |
Examples are My Hawk stock speedometer was 5-6 mph off. I replaced it with a more accurate digital speedometer. My X22R was 10 mph off and bought a speedometer calibrator to get it dead on accurate.
Are you still running the stock exhaust and carburetor with stock jets? If you haven't tuned it or installed a free flowing exhaust the performance will be on the low end.
04-28-2020, 05:34 PM | #348 |
Yes it’s got stock exhaust and an stock carb parts
04-28-2020, 06:45 PM | #349 |
Your average chinabike, regardless of who made it or what it is, is usually off about 4 to 6mph at highway speeds. Aka, if it says 60, its really doing 55ish
04-28-2020, 07:21 PM | #350 |
So technically doing 45mph instead of 50mph
04-28-2020, 08:24 PM | #351 |
What jets would you recommend??
04-28-2020, 10:27 PM | #352 |
Would drilling holes around the inside of the exhaust around the baffle make any difference in performance?
04-28-2020, 10:53 PM | #353 |
Thats the general rule, give or take a couple MPH maybe. At 50 indicated you might be doing 46 to 48. A GPS Speedo app on your phone can help you track the difference.
That depends on a lot of factors, but a good starting rule of thumb with most of these motors tends to be around a 105 main jet with no other mods at lower altitudes. Pilot jet depends on what style it has, but typically the most common sizes are 36,38, or 40. for a Keihin jet. It really helps to know your starting point to be able to make any suggestions. Generally that can help improve flow a bit. Removing the catalysts from these bikes if often even more effective in terms of opening up their breathing.
04-28-2020, 10:56 PM | #354 |
O ok ty sir
04-28-2020, 10:58 PM | #355 |
How would I remove the baffle it’s got rivets on the outside and if so do the holes were the rivets were need to be covered ?
09-22-2020, 03:18 PM | #356 |
What’s the size of the rear sprocket on the Df250rtf villain chopper???
09-22-2020, 05:28 PM | #357 |
I’m wanting to downgrade for more top end speed
