07-08-2014, 10:56 PM | #1 |
'04 flywing mx 150 help with wiring!
Just picked up a 2004 flywing mx 150. I paid almost nothing for it.
The only real problem i am having is with the wiring. It was all cut up. So here is what i have, Coming from the engine, there are 6 wires. Green with white stripe, Green with white stripe, Black with red stripe, Pink, Blue, And a yellow. And i have a cdi box with a 2 pin and a 4 pin connector. What wire is what? Any help, pictures or diagrams of this specific model would be great. |
07-09-2014, 12:59 AM | #2 |
--- Std Honda color? Bl/R EXT P & Y AC out/ ie. to rectifier Use multi meter find out the truth 1st, used bike might wired differently. --- The "ancestor" is wired as:
07-09-2014, 02:38 PM | #3 |
Wow thank you. This helps a little. Wish i could read chinese.
07-11-2014, 03:37 AM | #4 |
The later model (kick + electric start):
http://josemaco.files.wordpress.com/...h-62ktjam5.pdf
07-12-2014, 11:51 AM | #5 |
I cant download that file for some reason. How do i pull the flywheel to access the stator? Must i have a puller? Or can i just remove the nut and tap it off?
07-12-2014, 12:03 PM | #6 |
After 9 tries i was able to download.
08-29-2020, 04:42 PM | #7 |
Flywing Stator Replacement
Yes, you will need a puller to remove the Flywheel. I used a 6" puller. Mine was rusted on, so it almost broke getting it off. Finding the replacement stator was nearly impossible. I got it from China. I bought extra if you need/want to buy one. Good luck. My wiring is still flaky on the rest of it. Getting intermittent spark now. Thank you for the wiring diagrams!
08-29-2020, 05:40 PM | #8 | |
