Go Back   ChinaRiders Forums > Technical/Performance > Adventure Bikes > Zongshen RX4
Old 10-30-2019, 12:04 PM   #181
Working_ZS   Working_ZS is offline
Originally Posted by 1cylinderwonder View Post
...I’m tall and hoping the TALL SEAT will give me more leg room, instead of trying to find foot peg lower adapters. Also when lowering the foot pegs you reduce cornering clearance.
PCG
I have the tall seat and can say that I reach the ground fine. I only have a 29" inseam, so I'm either on the balls of my feet, or I slide one butt cheek off to the side to flat foot it. If your inseam is greater than mine, then you will have no problems. And yes, the seat helps greatly with legroom. I highly recommend it. It also has firmer foam, so longer rides are more comfortable. The stock seat starts to feel uncomfortable for me after about an hour of riding; it takes 2 1/2 to 3 hours before I start to get antsy with the tall seat.
Old 10-30-2019, 12:08 PM   #182
Single cylinder motorcycle vibrations:
At what engine rpms and highway speeds does the single cylinder engine of the RX4 create hard vibrations that make the rear view mirrors vibrate so much that the rider can not see much behind. My BMW G310GS has this problem when I’m riding at certain speeds.
I want to know if you can cruise at WHAT SPEED on the highways and still be able to view traffic in the bikes rear view mirrors. I’m hoping that if you’re cruising at 60 mph in 5th or 6th gear the mirror images are not vibrating and ruining the rear view.
Please explain in detail how to avoid rear view mirror blurring.
Thanks,
PCG
There is some vibration at 60 MPH, but it is very minimal; and nothing at all like the RX3. You can discern the difference between a car vs a truck behind you, for example. I have not tried my RX3's Double Take RAM mounted mirrors out on the RX4, but I can tell you that the RX4's OEM mirror vibrations match, or best, the Double Take mirrors vibration when they are installed on the RX3. I would think that the Double Take mirrors would completely eliminate vibration when mounted on an RX4. And vibration is about all that you would need them for, since the RX4's mirrors do not hit the ground when the bike goes down. At least not on pavement; I can vouch for that personally. If I get a chance, when the weather clears here, I'll switch over one of the RX3's Double Take mirrors and let yo uknow how it does in the 55-75 MPH range. Supposed to rain the next two days, so it will probably be Friday or Saturday before I can get to it.
Old 10-30-2019, 12:16 PM   #183
Originally Posted by franque View Post
Just add some bar end weights/fill the bars with lead shot, it will dampen the frequency that they vibrate at.
The RX4 is already equipped with bar end weights. The lead shot might help, however, if the rider feels that vibration is a problem. Having said that, the RX4 has virtually no vibration in the handle bar, unless you are really lugging the engine down in the 2500-3000 RPM range. Even then, you tend to feel it more in the seat of your pants than in the bars or pegs.
Old 10-31-2019, 02:20 AM   #184
G19Tony   G19Tony is offline
G19Tony's Avatar
Grin RX-4 purchase
I was an early adopter of the RX-3, but sold it after around 1000 miles. I got distracted by something else. I'll be taking delivery of my RX4 mid November. I'm going to do a fly and ride, and ride it home to Vegas. I've found a route that keeps me off the interstate. It will take longer, but that's the idea. I'm also having all the farkles installed at CSC. I purchased a Garmin Zumo 396 LMT-S that they will hardwire to the bike for me when I get there. The OEM spoked wheels will get shipped back to me. It will be nice to have a bike, that I shouldn't have to do anything to, for a change.
Aluminum wheels with the 80/20 tires.
Tourfella luggage
Quick drain plug
Apollo heated grips
Aluminum skid plate
Wrap around handguards
LED spotlights w/switch
Seat Concepts narrow seat
Honda CB300R ABS
Old 10-31-2019, 01:04 PM   #185
Math Teacher   Math Teacher is offline
My RX4 is smooth up up 6000 rpm then gets a little buzz around 6500 and is smooth again at 7000 and up. Not enough for me to feel and does not badly distort the mirrors. I would not have even noticed it, except that I hear a slight vibration in the aluminum skid plate. When I go back and ride my old RX3 it sure feels light weight and under powered compared to the RX4.
Old 11-03-2019, 11:06 AM   #186
Musictrek   Musictrek is offline
Musictrek's Avatar
Rx4
Old 11-06-2019, 11:10 AM   #187
1cylinderwonder   1cylinderwonder is offline
I Contacted CSC—-NO REPLY!
Without a center stand, a longer/taller side stand, or a well connected/supportive trackstand the RX4 bike is too unstable doing major work.
I sent CSC an inquiry about the above information, but have not received an answer or reply!! I guess it’s not a problem for them since they have all those large motorcycle lifts in their shop!
PCG[/QUOTE]
Old 11-06-2019, 01:11 PM   #188
Working on RX4
Go to Amazon or to you favorite motorcycle supply shop and find a motorcycle kickstand plate or foot or pad as it is called. This will add length and stability to the kickstand. Then find a "SnapJack" from your shop or Amazon. This makes the kickstand act like part of a center stand while the SnapJack acts like the other part of the center stand. I have used this setup on both the front and rear wheel. It is stable, reasonably priced, and light weight.
Old 11-06-2019, 03:25 PM   #189
A normal kickstand plate won't do the job. The OEM kickstand would have to be extended about 1.5" (maybe even more) to reduce the lean angle enough to be stable.
Old 11-07-2019, 11:06 AM   #190
Question Try Removing Your Rear Wheel
Try removing your bike’s rear wheel using the kickstand foot plate and a SnapJack and see how your bike wants to slip off the non-secured SnapJack. Straining to move the rear wheel forward to remove the chain and rear disc from the caliper and the rear axle usually makes the bike fall off the kickstand and the SnapJack, especially if the bike is a very heavy model. I’ve been there and done that!
PCG
Old 11-07-2019, 11:53 AM   #191
It is true that the SnapJack is not as stable as a good center stand. But when it is your only option on the road, you find a way to make it work. It comes with a good Velcro strap to clamp the front brake lever so the front wheel locks. That helps keep the bike from moving. It is not really meant for wheel removal, but if it is your only option, it can be done. For other type of work, the bike will be reasonably safe & stable. Be careful.
Old 11-07-2019, 12:09 PM   #192
Juanro   Juanro is offline
Juanro's Avatar
If you really need to remove a wheel, and really really have no other choice, say, you're on a trip in the middle of nowhere, you can always lay the bike on its side and work there. Good crash bars as the RX3/4 have, helps a lot. Not pretty, not easy, but at least it won't go anywhere. I even serviced my clutch that way once, without even removing the oil.
Old 11-07-2019, 01:19 PM   #193
calvarez   calvarez is offline
But I can tell you from experience that the tank will leak fuel. Could be just my bike, but when knocked over in a parking lot there was a lot of fuel spillage.
2016 RX3
2002 Honda CBR1100XX
Old 11-07-2019, 01:50 PM   #194
Juanro's Avatar
Mhh mine doesn't
File Type: jpg 66348244_10157438136714532_7869043899237400576_o.jpg (73.7 KB, 1103 views)
Old 11-08-2019, 11:53 AM   #195
How full was the tank? When mine leaked it was probably over 3/4 full.
2016 RX3
Search this Thread:
Advanced Search
Display Modes
