09-09-2017, 08:13 PM | #16 |
ok i might just look for a yamaha tricker sprocket from europe for now. but i will post the sprocket dimensions later. thanks guys.
09-09-2017, 10:05 PM | #17 |
From what I understand, many Magician owners have simply done a 17 tooth front sprocket and been more than happy with that gear combination for road use. If you do a 17 front and find you still would like to drop the revs down to gain a little more highway useability, then losing a couple of teeth on the rear would be the next step. Seeing as front sprockets are $10 and easy to install, to me it makes the most sense to start there. The 17 front sprocket fits fine in the Hawk/Magician CG250 engine. I had to trim my sprocket cover to fit because I flipped my front sprocket on the counter shaft and I am also running an O-ring chain that is wider than a standard chain, so it was just big enough to cause a problem. Before flipping the front sprocket, I just had to give my cover a little bump to get over the chain, but otherwise it never interfered.
09-29-2019, 05:38 PM | #18 |
No it's not an off the shelf sprocket.
09-29-2019, 05:41 PM | #19 | |
09-29-2019, 06:00 PM | #20 | |
Quick, tell me another one before I quit laughing and pass that joint! |
magician 250cc |
