Old 07-19-2019, 06:04 PM   #1
scoot newb   scoot newb is offline
scoot newb's Avatar
Brake cleaner on the front disk. Now it doesn't work well.
My front brakes had a squeak so I sprayed on brake cleaner and wiped it down with a paper towel. Now they suck. I'm not sure how to proceed. HALP
Old 07-20-2019, 01:27 AM   #2
Azhule   Azhule is offline
Brake cleaner usually evaporates quickly causing little issues but overspraying can cause a few known issues with the caliper, things might need to re "grease/lube" any pins, guides, and or the piston(s) on the brake caliper... brake cleaner is also really harsh on o-rings/gaskets/seals, can swell or dry/crack them depending on the brand used it might do both
Make sure you use a "Disk Brake" rated lube (I like to use AGS branded grease/lubes when working on brake parts), watch a few youtube vids if needed, it's fairly easy to do with basic tools, a block of wood (don't shoot the piston out of the caliper ) with some "big pliers", and a little common sense
Could also just be an air bubble worked it's way into the brake line, bleeding the brakes with fresh fluid might be the real problem
Old 07-20-2019, 02:21 AM   #3
scoot newb's Avatar
I was careful with the spray. I only sprayed it on the rotor and had a towel behind it to stop it from getting on the rims. Then I wiped it down with a paper towel, rotated the wheel and did it again. I thought maybe the rotor or pads are now glazed because of it.
The problem with the brake not working well happened right after applying the cleaner
Search this Thread:
Advanced Search
Display Modes
