03-03-2019, 05:10 AM | #2 |
In the USA?
https://store.cscmotorcycles.com/TT2...ARTS-s/306.htm Or I can supply colored cables from china |
03-03-2019, 09:43 AM | #3 |
I pieced together a kit like this for my Roketa, since i already had the master cylinder from another project...once you do this you will never look back.... trust me... https://www.ebay.com/itm/7-8-Motorcy...JT9iuk9eODosRQ
03-03-2019, 09:48 AM | #4 | |
How would you rate the quality and durability of the unit that you linked? |
03-03-2019, 09:57 AM | #5 | |
03-03-2019, 10:06 AM | #6 | |
What made you put on that master cylinder in the first place? What bike do you have, and why did you put in heavier clutch springs? |
03-03-2019, 10:12 AM | #7 |
Master cylinder is for the clutch, since it got swapped to hydro. Heavy clutch springs is because i am a 6'2" 280# fatarse that otherwise seems to overheat and weaken clutch springs...LOL bike is a 2007 Roketa DB07A converted to supermoto and has a dr650 fuel tank swapped onto it...
03-03-2019, 10:18 AM | #8 | |
While I'm not the heaviest guy, I'm also not light. Plus with full gear and if I get one obviously I'll be using it to commute to college so it'll also have a big ass backpack strapped to it. I'm very curious about the dr650 fuel tank. Did it just fit right on or did you have to modify it to fit? |
03-03-2019, 01:00 PM | #9 |
Does this kit come with the fluid it needs? Or is it just the lever?
Hawk 250 Lithium Battery, Mikuni Carb 110 main jet, Bark Busters with Mirrors, Extended Mixture Screw, 428 O-ring Chain, 17-15/40 sprockets, Digital Cluster, Cycra YZ250F Skid Plate, Oil Cooler |
03-03-2019, 01:31 PM | #10 |
http://www.kidsatvparts.com/
I picked one up locally but you can also order. I don’t remember the correct size but just measure your cable. |
03-03-2019, 01:36 PM | #11 |
I assume it doesn't and you would have to buy it.
03-03-2019, 01:42 PM | #12 | |
Disadvantages - cannot be bodge repaired like a cable when it fails and a little more expensive compared to a cable setup I have a complete hydro setup saved on Aliexpress to eventually put on my Hawk, and the rough cost is about $50. I prefer hydraulic clutch setups. Comparitively, a new clutch cable might cost $10-20.
03-03-2019, 01:55 PM | #13 | |
Now u am wondering about hydro breaks? I have seen them on some mountain bikes. |
03-03-2019, 04:34 PM | #14 | |
03-03-2019, 08:37 PM | #15 |
Hydraulic clutch a nice idea BUT the Chinese cylinders are mmmm yeah from what I have heard kinda hit n miss quality.
Clucth springs or clutches there are several option in the number of clutch plates and clutch springs for most CG and CB engines 4 springs 5 springs 6 springs then something like 5-7 plates as well. |
