10-15-2018, 04:21 PM | #1 |
Hellcat 125
Have a new hellcat 125. Taking deliver my speedo sensor was broke, choke tab broke and the bottom is about stripped out of the handlebar for it. Shipping strap went through the plastics. Otherwise bike runs great. Sadly I am one that can’t change to MPH.
Have exhaust on the way, chain, 14t front sprocket and looking to upgrade rear bolt and swing arm bolt. Anyone have a list of all Grom parts that fit. This will end up being my wife’s as I am looking to get the Benelli TNT. |
10-16-2018, 06:43 PM | #2 |
nice.
Get the carb/pod filter and remove the airbox. I run a 17t front but try what you like best. Most grom parts fit but on the same hand a lot don't without some modn or just don't, Lot of trial and error. Also some bolts are different sizes then a grom like engine mounting bolts. Most everything on the stock hellcat can be upgraded and kind of should be. You can find most aftermarket parts that will work online. |
10-17-2018, 07:40 AM | #3 |
Thanks Chinabike. Kid of what I have gathered from looking around. Not even a whole lot of specifics about the TaoTao. This headlight thing is driving me nuts, the running light works and the bright will come on if you pull that little trigger but the switch doesn't turn the brights on and the low beems don't work. I checked the bulb and it seems fine along with all wiring and connections. Boggled.
10-17-2018, 05:21 PM | #4 |
Sounds like it’s time to pull out the voltmeter and find out where the power stops.
Keep us posted on what you find!
10-17-2018, 07:35 PM | #5 | |
10-18-2018, 05:36 AM | #6 |
On off on the throttle side control? Hmm... Man that would be fabulous if that were it.
10-19-2018, 10:02 PM | #7 |
Was that it?
10-21-2018, 08:11 AM | #8 |
Wouldn’t you know it? So glad!!
