03-29-2018, 07:34 PM | #16 |
The bottom one is two jets. That is your main jet and needle jet still screwed together.
03-30-2018, 02:50 AM | #18 |
at around 600 feet (i think) i run 40/115 in my storm ... was a little rich before the cat was out and opened the air box, not sure yet after that. i suspect until i get a better exit hole, it will still be a tad rich.
03-30-2018, 03:08 AM | #19 |
That's why we are here. Don't feel bad about not knowing either. Not many people even know how a carb works, let alone how to identify the individual parts. Knowing is half the battle, and we all had to learn at some point. I learned about carbs on a 1976 Buick 455 with a quardrajet carb at the age of 16. My dad helped me remove it, sat me down at a table, gave me some tools, a manual, and let me get to work. Trust me, I made mistakes lol.
04-18-2018, 04:30 PM | #20 |
I'm still having trouble finding the jets that I posted in post 15. I purchased to sets and they are not even close. I even bought an online carb rebuild kit listed for this carb and it was the wrong one. I'm about to just buy the mikuni but what are your thoughts. Any help for the right parts would be greatly appreciated.
04-18-2018, 04:31 PM | #21 |
@Barlow where did you buy the jets for your storm. Thanks
04-18-2018, 07:48 PM | #22 | |
04-19-2018, 01:45 AM | #23 |
@ariel red hunter. Thanks I will try this and report back I appreciate the clarity which helped me to understand.
04-19-2018, 07:47 AM | #24 |
These are the jets you need I have a Brozz with the same Carb
pilot https://www.aliexpress.com/store/pro...261794843.html main https://www.aliexpress.com/store/pro...564568976sRT63
2016 Brozz |
04-19-2018, 12:14 PM | #25 |
Thank you for your response. Wrapping your mind around the concept of the three stages of this style of carburation makes the whole problem easier to solve. One more suggestion if I may - never make more than one change at a time!...ARH
04-20-2018, 01:23 PM | #26 |
Thanks for the links, I don't have any problem with this carb so far so I'll rejet with the exhaust modifications and see how it goes.
04-20-2018, 04:05 PM | #27 |
So I took apart the two jets and added a 120 jet and it had the 34. I started it and it ran fine but then eventually died out. I used the hex 120 which fit instead of a round 105. When people say go to the Mikuni they are not kidding but it sure is fun going back and forth taking things off etc.etc.
04-20-2018, 11:09 PM | #28 |
Let me know where you end up so I can have a starting place! Thanks.
