Old 08-03-2017, 08:43 PM   #1
Ooey, gooey, gluey RX3
Ok, I peeled the blue "speed", etc.. stickers off the white RX3. I just couldn't deal with the blue anymore.
Regardless of heat gun, ice packs, different peeling techniques, the glue REFUSED to stay on the sticker and stuck completely to the bike. I didn't think much of it until I went to try to remove the dreaded mess.
I used to work in auto body many years ago. I've peeled many-a-sticker, label and graphic. Never a real problem. A little glue gets left behind, either dabbing the wadded up sticker on it or a little wd40 and it was all good! This stuff!? It must be nuclear glue from a bizarre glue factory somewhere outside Chernobyl.
I've soaked it in Goo Gone, WD40, brake kleen, even gas additive....to no avail....and I mean SOAKED it. Let stand for 10 minutes at a time, running wet. I've even tried polishing compound. The biggest panic is there's a LOT of it.
Any favorite concoctions for removing this wicked crap? Peanut butter? Mayo? Anything? Did anyone else experience this?
Old 08-03-2017, 10:14 PM   #2
rd1959   rd1959 is offline
If you're married or have a girlfriend this won't be popular with them but, I used to use fingernail polish remover. Seeing's how you're having no luck with stronger stuff it probably won't work either. Oh, how about bug and tar remover?
Old 08-03-2017, 10:24 PM   #3
tinman tim   tinman tim is offline
tinman tim's Avatar
PVC pipe cleaner, perhaps?
Old 08-04-2017, 12:11 AM   #4
Merlin   Merlin is offline
Exclamation Been there done that.
I had the very same problem. Use acetone. Just check on a part that cant be seen first.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 08-04-2017, 12:46 AM   #5
1cylinderwonder   1cylinderwonder is offline
Fingernail polish remover is acetone, which usually removes the paint or dulls the plastic finish. As Merlin said, check on a spot that won't be seen.
Old 08-04-2017, 04:59 AM   #6
pete   pete is offline
pete's Avatar
paint thinners or CRC electoclean...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-04-2017, 09:04 AM   #7
goat67   goat67 is offline
goat67's Avatar
Believe it or not Lighter Fluid you may be surprised.
2016 Brozz
Old 08-04-2017, 10:19 AM   #8
Thanks for all the suggestions, gang. I was just the shy side of using gas.
I'll heist Mrs. 2LZ nail polish remover this evening and see how it goes. It's a mess.
goat67, Zippo fluid or BBQ lighter fluid?
The other thing is, when I bought the bikes used, the seller gave me a full set of brand new white body parts that I now have stored away...but they're also full of blue stickers. I don't want to create double the mess. The upside is if I wreck a piece with some wacky chemical, I can at least replace it.
Old 08-04-2017, 10:21 AM   #9
Sullybiker   Sullybiker is offline
Sullybiker's Avatar
Well the stickers are definitely gone
Old 08-04-2017, 12:36 PM   #10
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Is that the new Zongshen 450cc? Lol
Old 08-05-2017, 08:55 AM   #11
goat67's Avatar
Zippo. It Is ronsonol brand works and does not damage the paint
2016 Brozz
Old 08-05-2017, 09:24 AM   #12
Curious to know what kind of adhesive they used that is that virulent? Lol, would be handy to have some for the things you want to stay stuck!
Old 08-05-2017, 09:48 AM   #13
ben2go   ben2go is offline
You worked in a body shop and don't know about adhesive removers? It's been 22 years since I worked in a body shop and all we ever used was 3m adhesive remover. It's never failed to remove any adhesives, even those awful graphics they used to put on dirt bikes in the 80's.
It can usually be bought cheaper locally.
https://www.amazon.com/3M-General-Pu...7c4b8aec1dcba4
Old 08-07-2017, 10:24 AM   #14
Well, it's only been about 38 years. ;-)
That's probably the ONLY thing I didn't try.
Bottom line was, the best remover was a long fought battle with WD40 and a blade.....but that was only on the rear panels where it said "RX3". The tank wings were a completely different story.
I ended up getting some Goof Off at Lowes (about the only thing I didn't have besides 3M remover). It's the super stuff made for "Gorilla Glue, Super Glue, etc...". I thought for sure it would work....and it did!!! The only problem was that the very second it broke through the glue, it took the paint with it down to the plastic. :-(
So, the wings got stripped, wet sanded and primed 3 times, then wet sanded again and 3 coats of gloss white. What a nightmare just for some glue.
If you ever peel your stickers and get left this mess, good luck. Next time you hear someone tell you your bike is "cheap Chinese junk"....you can rest assured that the Chinese make the best glue on planet Earth.
Old 08-07-2017, 11:03 AM   #15
willy dog   willy dog is offline
willy dog's Avatar
i peeled my stickers off when it was around 20 below left no glue but did take some of the paint off i knew better just that speed sticker was bothering me just bought spray can of label and sticker remover by turtle wax for my truck don't know what's in it but it's the best stuff i ever used
Peace and Zong Life
Search this Thread:
Advanced Search
Display Modes
