04-13-2017, 12:30 AM | #16 | |
04-13-2017, 06:37 AM | #17 |
04-13-2017, 11:31 AM | #18 | |
If yes , does it have screws to get into the bowl? That original Keihin Carb has run rich with low fuel milage so I think i will give the mikuni a try. Cheap enough Hang in there with the healing, getting better every day
04-13-2017, 12:32 PM | #19 |
Yep, went on the Blaze. Four phillips screws secure the bowl to the carb, remove those and you have easy access to the jets. For $30 you can't go wrong. It came equipped with 100 main and 20 pilot jets, so you will want to rejet it.
Thanks for the healing thoughts, I have a follow up with the dentist in a couple of hours, hopefully getting the stitches out and working on a time line for getting the lower partials. |
04-13-2017, 01:32 PM | #20 | |
04-13-2017, 04:57 PM | #21 |
Well, I got back from the dentist, the stiches came out, and a follow up for a deep cleaning and fillings on the remaining teeth is scheduled for early May, the a week later impressions for the partials will be done. Hopefully, I'll be back to normal eating by the time camping season starts in earnest (Soup around the campfire just doesn't have the same appeal as hamburgers, dogs and brats!).
After I got home, I fixed the sticky throttle, I sprayed a little cable lube inside the throttle tube and worked it back and forth and it returns nicely. We then extracted it from the basement and gave her a quick bath, and I applied some Blackfire paint sealant to keep the paint looking nice. I think it came out rather nicely: Now for the bad side. After sitting it appears the clutch is locked up. as soon as I kick it in gear if the brake is applied it starts to bog down and stall (So not 100% locked) if the brake is not applied, it will take off. I suspected this might have happened, because when I tried to roll it back and forth in gear with the clutch in, it wouldn't move, so fortunately when I put it in gear I had the brake applied! Otherwise I probably would have been paying a deductible on the rental too! Any one know an easy way to freeing up the clutch plates with out taking off the side cover? I'll be doing some searching on it but if anyone has any ideas, let me know! |
04-13-2017, 05:01 PM | #22 |
If the oil is old... drain it out... refill with the proper amount of new oil... tip the bike over and lay it down on the right side (clutch pack side)... let it set over night
This usually helps get the clutch plates properly soaked again without having to take everything apart
04-13-2017, 05:33 PM | #23 |
Nope brand new oil (well, a month or so old, but about 5 minutes of run time on it), Valvoline 4T 10w40. I'll try laying it on it's side before I go to work tomorrow, the try and get her going again tomorrow evening. I may try rocking it back and forth after dinner just to see if that frees it up. Thanks for the tip!
04-13-2017, 08:19 PM | #24 |
I was thinking the same as az said (as I have learned here) but he would know better being a
mechinic. Also if the soak doesn't do the trick I would jack it up and ratchet it down good and run the thing in idle to heat that sucker up. Put an electric fan in front to help cool while its running. Then let er cool down and see what happens before you go into the case. I would think the heat cool effect would break er loose I bet one way or the other it will take care of it unless it's something major (like your mouth). You need to say healthy for those little helpless young-ens. P.s. Did you buy a jet assortment for that mikuni from that same ebay seller. Was hoping to find jets too but none so far other than other places.
04-13-2017, 08:37 PM | #25 |
Oh...., what was I looking for...jets, jets, that's right, carburetor Jets .
04-14-2017, 04:26 AM | #26 |
Hertz, let me tell ya, don't be fooled. Those girls don't really know what they are doing with that scanner
04-14-2017, 07:48 AM | #27 |
That's like telling me they can't find the UPC Bar Code. Even slow people at the self check out can find it after a few rotations...
04-14-2017, 05:22 PM | #28 | |
Azhule, I officially have a man crush on you! Laid it down on the right side before I left for work this morning. Got home a little bit ago, and righted her and fired her up. I let her run for 5-10 minutes at a high idle (I need to adjust the idle down still) until everything got nice and warm, then turned her off. I put her in gear and rocked her back and forth with the clutch in and at first nothing, but after a minute of so of rocking, it popped and started rolling freely! After dinner I'm going to take her for a little spin. I also adjusted the idle down since everything was nice and warm. |
04-14-2017, 07:11 PM | #29 |
Wow! Carbs and jets ARE sexy!!
04-15-2017, 12:07 AM | #30 | |
