Old 04-03-2017, 08:53 PM   #166
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
Is that an old FWD Chev sedan, like a Lumina?
They are chevrolet parts but they are off of a 90s era 2500 pickup truck.
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 04-04-2017, 08:38 PM   #167
suspension mounts and a-arms are finished, drive train axels are cut and installed. waiting on the machine shop for the flanges to integrate with CV axels. I added a jackshaft since I may have needed to offset the chain for the flange couplers, it now has an additional reduction there as well as a larger rear sprocket, all chains are now 530 /#50.
Old 04-04-2017, 08:47 PM   #168
If you like math and are interested in the gearing calculations here is the calculator I created
https://docs.google.com/spreadsheets...it?usp=sharing
Old 04-05-2017, 11:10 AM   #169
You're an Excel star! Do you think you'll hit the theoretical 73mph in 6th?
Old 04-05-2017, 12:32 PM   #170
hard to say, I am hoping to at least be able to reach 55 in 6th without needing to be on the redline. Anything beyond that is just a bonus!
Old 04-05-2017, 01:11 PM   #171
Welcome back, WA! Cool project!
I figured you're be designing Mars landers for NASA by now....... ;-)
Old 04-05-2017, 10:35 PM   #172
Drive flanges are installed!
just have to extend the cvs, finish weld everything, and repaint
Old 04-16-2017, 12:57 AM   #173
Not quite but I have created a design for a prototype reversible gear box that should comfortably hold 200 hp and easily be retrofitted in to motorcycle engine powered buggies and shifter carts. There is only one other out there and is priced at a ridiculous $1500 and forces the output shaft to be offset from the original driveline.
Old 04-16-2017, 03:31 AM   #174
pete   pete is offline
pete's Avatar
looks like a fun toy..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 05-08-2017, 06:40 PM   #175
Jackshaft arrangement
Switched to modified porsche 930 cv joint on the upper part of the shaft since the chevrolet ones could not handle the 29 degrees of max angle I wanted.
Old 05-15-2017, 02:03 AM   #176
It is once again back on the road, Just have to machine up the rear brake disc, make the caliper mount, and get these crappy carbs to work properly and I will try and get some action videos out.
Old 05-15-2017, 01:06 PM   #177
I'm looking forward to seeing that crazy articulation in action!
Old 05-17-2017, 01:00 AM   #178
Final shaft chain tensioners
back on the ground with the old rear wheels on the front!
Old 05-17-2017, 11:47 AM   #179
That poor Honda motor on the bench needs some love.
Old 05-17-2017, 04:46 PM   #180
It got a new clutch and is back to the customer now. It is for some sort of three wheeler project.
Since these pictures the shop is unrecognizable, has been getting cleaned and upgraded for the last week!
Search this Thread:
Advanced Search
Display Modes
