Thanks to Bogieboy's inspiration and to Emerikol's awesome new supplied fuel tank.
Got the Suzuki dr650 tank mounted to the Bashan blaze (bashzuki?). Stock 1.8 gal tank only got me about 62 miles. With my poor fuel milage of 37mpg (basically wot mileage) and the added 1 gal reserve I carry I can get out to the middle of nowhere now where the stations are few. Total range should be about 165 miles or so. Ready for hooked on phoenix (yea right ![]() Had to lift the tank up due to frame clearances on underside of tank.i used toilet stud bolts to accomplish this. What ever works. Seems to work ok so far. I think bogieboys tank was able to sit lower because his roketa triple tree is designed different than mine, thus more room for handlebar clearence. When that big ol metal tank is near empty it kinda echos a little, just like my big ol stomach when it's empty ![]() Also installed my $27 delivered digital tacho/speedo. Am very happy to have accuracy in MPH for a change. Had to lower the aux LEDs with a 1 inch bracket to clear the tank. Handlebars work from stop to stop (took a day of fitting to figure that one out ![]() It took awhile to get this thread going but wanted to get it after all finished. Ran in to lots of little hurdles to clear but easy enough if you just take them one-at-a-time. Still can't load pics from my tablet, after that chinariders.net site trouble. ![]() https://drive.google.com/folderview?...ENWTVJLblNuTWs
Looks good.
#3 | |
Looks good! i havent even gotten the bike out of the basement yet...LOL still need to replace the starter solenoid and do an oil change......time... never enough of it...
haha yeah... there was about a 1/8th inch area where the tank wouldnt hit...go up or down a hair from there, and youre hitting... took me a while to figure out and eyeball the hole for the frame for the front...LOL
Nice job on the fit up. If you don't like that gap between the seat and tank, I would suggest a heat gun to soften up the plastic to form it down. You'll have to pull the staples out from the seat to allow it to move, though. Also, you'll have to cut a triangle out of both sides of the front lower part of the seat pan. This will allow it to form down to the tank without bulging out...or in.
