Old 10-26-2016, 07:44 PM   #31
GeneralTso   GeneralTso is offline
GeneralTso's Avatar
Originally Posted by Mudflap View Post
I torque the exhaust nuts to 15 ft lb, going by the Honda factory CG125 service manual. Also it's important to install the exhaust system in the right order. Install header first, snug exhaust nuts finger tight to make sure the flange is seated squarely on the gasket. Then install the rest of the system loosly, torque the exhaust nuts, then tighten the rest of the exhaust mounting bolts.
Yes I know but maybe I didn't pay attention, I'm going to redo it this weekend. Thankso guys...
2005 Kazuma Cheetah 200 (Swamp Thing)
Old 10-27-2016, 09:06 AM   #32
Azhule   Azhule is offline
I think I only torqued mine header nuts to 12ft lbs... I too was afraid to break something off going over that ... might get brave one of these days and get closer to the Honda torque specs
Old 10-27-2016, 12:11 PM   #33
A little red Loctite does a good job of keeping the nuts secure. If you have enough stud protruding after tightening the nuts, you can always double-nut.
Old 10-31-2016, 11:48 PM   #34
GeneralTso's Avatar
So busted out the torque wrench tonight and hit those two header bolts. Set it for 15lbs and it took 3 to 4 good turns to get them where they needed to be. Will fire it up tomorrow and see if it helped at all.
Thanks guys
Search this Thread:
Advanced Search
Display Modes
