10-27-2016, 03:46 PM | #1 |
Why 17/45 Sprockets on Hawk 250?
Why are the majority of the Hawk owners going with 17/45 sprockets (2.65)? Why not 15/40(2.67)? It will be close to the same ratio and would only need to change the rear sprocket. I know I would have to cut the chain but that's easy stuff. This would shorten the chain by 2 links. Shorter chain less stretching. The 45 tooth sprockets are $25 and not in stock but I can get a 40 tooth for under $19. Has anyone done this combo with any issues? Just think outside the box.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-18-2017 at 03:55 PM. |
10-27-2016, 05:33 PM | #2 |
I'm running 16/40 combo that's been working well for me.
10-27-2016, 05:45 PM | #3 |
That's good to know, so I should be ok with 15/40. I could always do the 16t on front if I feel the need to.
10-27-2016, 06:02 PM | #4 | |
10-27-2016, 08:24 PM | #5 |
A new chain is in the plan once I change the sprocket and I'm satisfied with the setup.
10-28-2016, 01:22 AM | #6 |
Why not try it? What is the worse that could happen?
10-28-2016, 06:31 AM | #7 |
Ordering the 40t today. I knew the sprocket would work. I was just concerned if anyone had any issues with the combination of the 15/40 sprockets. I'm still waiting on my jets. They're on that slow boat from China.
10-28-2016, 09:46 AM | #8 |
What is your top speed with this setup? Do you lose any low end for off-road? I may just order the 16t to try it out.
10-29-2016, 08:11 AM | #9 |
I've thought about this as well. I'm currently running a 17/45 and have toyed with the idea of going to a 17/43???
If I were to do it again, I think perhaps a 16/43 (2.69) may be the sweet spot to start. Easier and cheaper to change the front if you want to make further changes, dropping all the way down to a 40 rear seems extreme to me, and a 43 rear leaves you options of adjusting the front to a 15, 16, or 17? Is a 14 front available, or too small IDK... |
10-29-2016, 03:27 PM | #10 | |
10-31-2016, 01:52 PM | #11 |
My top speed with the 16/40 combo is still only around 70-75 mph depending on the incline and wind. Just not enough power to pull high speeds consistently. I don't ride off road with the Hawk too much but for easy trails it works well for me.
10-31-2016, 02:46 PM | #12 |
According to my tracking # i'll get my 40t tomorrow. I think the 15/40 will work out perfect but good to know that the 16/40 combo works. I'm about 50/50 on and off road and the off road is mostly flat with only a few man made hills. No hills in South Louisiana lol. The Corp of engineers have set up a great off road area in the Bonnet Carre Spillway in Norco , La. with about 5.5 - 6 miles of trails.
10-31-2016, 03:11 PM | #13 |
O-ring chain
Has anyone tried this chain? XFMT Gold Oil-Sealed Custom O-Ring Heavy Duty Drive 428 x 136 Chain https://www.amazon.com/dp/B019OEZFKW...I20PBHCDVW0MML Not a bad price.
10-31-2016, 09:14 PM | #14 |
11-01-2016, 08:00 AM | #15 | |
