Old 11-07-2015, 08:31 PM   #1
AZRider   AZRider is offline
Chain and sprocket replacement
In case you weren't able to attend CSC's chain maintenance tutorial or view their video, Motorcyclist Magazine has posted an online video on replacing your chain and sprockets with some useful tips. It will also give you a chance to invite your neighbor over for a beer in return for his help with the wrenching.
http://www.motorcyclistonline.com/mc...clist-magazine
George
2016 CanAm Spyder F3-L
Old 11-07-2015, 08:43 PM   #2
detours   detours is offline
detours's Avatar
Thanks for the link! I wish I could have watched CSC's video, but this will help a lot.
Red 5 standing by!
2015 CSC red RX3 with 19" front wheel, Shinko 804/805, skid plate, tall seat, 13T/45T sprockets, progressive shock, Winyoochanok windshield, GENSSI LED headlight, SW-Motech tankbag, Shorai Lithium battery
2014 Ural Patrol
Old 11-07-2015, 08:45 PM   #3
Thanks for posting the good link on an important topic, George. Here is the video.
Old 11-07-2015, 09:22 PM   #4
The MC Garage video says you should rivet your chain, but I much prefer drive chains with a master link clip. A master link clip is much easier to install, and I have never had a failure of a master link clip. Also, it is much easier to remove an old chain with a master link clip. Otherwise, you need to grind one of the pins, and push the pin out of the chain with a chain breaker tool.
Old 11-07-2015, 09:35 PM   #5
rtking   rtking is offline
If you download periscope and looke for CSC Motorcycles, the presentation Joe made will be available for another 14 hours or so, I think. (I think Periscope keeps presentations for 24 hour period, but not totally sure as this is my first time using Periscope.)
Old 11-07-2015, 10:10 PM   #6
Spud, I'm sure that you're safe to do so with a 250, but with more powerful bikes, i believe that a riveted link is essential.
George
Old 11-07-2015, 11:44 PM   #7
roots   roots is offline
roots's Avatar
Since we are sortof on the topic. I watched the CSC live feed this morning and noticed the chain slack that Gerry allowed looked much more than what I did "following" specs. Basically, I think I set my chain to tight. I can get the appropriate movement up and down but with effort. Gerry's chain looked more like the chain freely moved up and down within spec. Does that make sense? So, do others push and pull (with all your might) the chain to check or gently move the chain up and down?
2015 RX-3 Cyclone (Orange)
Old 11-07-2015, 11:56 PM   #8
ElkSlayer   ElkSlayer is offline
Just watched the periscope video.... For me, it started with the new chain already on the bike? Did not see any disassembly...is that the way it originally was viewed?
Jim
Old 11-08-2015, 12:06 AM   #9
If you are racing a sport bike at high speeds, you probably should use a riveted link. However, I use a master link with a clip on my Honda XR650L, and I have ridden it over 90 mph without any problems whatsoever. At sea level the XR650L will reach a top speed well over 100 mph, and many, if not most owners, use a drive chain with a master link clip. We certainly won't have any problems running a master link with a clip on our Zongshen RX3 motorcycles. However, if someone prefers a riveted link, I think he should use a riveted link.
There is not a lot of lateral force on the clip. Therefore, if the clip is installed properly, it never causes a problem. If someone installs the clip improperly, that is a different matter. However, even if done poorly, a rivet is highly unlikely to fail, so it is definitely more fool proof.
Old 11-08-2015, 12:10 AM   #10
You should not have to "push and pull (with all your might)."
Old 11-08-2015, 12:41 AM   #11
roots's Avatar
Jim
Nope, the live show started with a couple sales pitches before talking about tools and replacement sprockets and such. Then the sparks flew!
That's a bummer you can't see the whole thing, I guess you just had to be there
Old 11-08-2015, 12:49 AM   #12
roots's Avatar
Alright, thanks Spud. But what if my might is much less than yours! So, use a quarter Spud might, slight might, or just the right might?
Anyway, I guess I now know that I need to loosen the tension on my chain.
Last edited by roots; 11-08-2015 at 12:51 AM. Reason: Wrong emoji as this is difficult on a smart phone.
Old 11-08-2015, 01:06 AM   #13
I'm sorry; I wasn't trying to be flippant. The drive chain should move easily, as you saw during the presentation. If it requires a lot of force to check the slack, your drive chain is probably too tight.
Old 11-08-2015, 02:40 PM   #14
Jay In Milpitas's Avatar
Chain slack video.
I searched through a number of videos before I settled on this one to explain chain slack (not tension) adjustment. Notice he says to check it with your butt on the seat! That's because of the geometry of the swing arm and sprocket arcs.
Hope this helps.
Search this Thread:
Advanced Search
Display Modes
