Old 07-08-2015, 04:18 PM   #1
chuckbiskut   chuckbiskut is offline
Question Hi-Bird QH-125-10
Greetings all,
First post and not sure if it's in the right place.
I recently purchased a 2007 Hi-Bird motorcycle and need the rear sprocket hub as the one that was on there is shattered. Also need the rubber thingies that go inside the wheel (dampeners?) oh and the bearings that were inside the hub were scratched. I could tell it had been moving around for a while.
As you can probably tell I am somewhat new to having to fix my ride.
thanks in advance.
Chuck
forgot to add a picture of what is left after hub was off.
Old 07-08-2015, 04:55 PM   #2
humanbeing's Avatar
That wheel is similar to 90s CB125T. U can compare it @ http://www.impex-jp.com/catalogs/mot.../11kc1fj7.html
Mark down what u need, we can find the compatible
Old 07-08-2015, 05:49 PM   #3
I apologize I could not read it and google wouldn't translate that site.
I have been able to grab the larger parts that formed the hub for the sprocket in the back. I would need that piece the rubber dampeners and the bearings. Here are a couple pictures of them.
Old 07-08-2015, 06:29 PM   #4
humanbeing's Avatar
It's the F12-1 in that link.
http://www.impex-jp.com/assets/image...012_F-12-1.png
http://www.impex-jp.com/assets/image...013_F-12-1.png
http://www.bike-parts-honda.com/moto...125TP-680.html
Old 07-08-2015, 06:48 PM   #5
I looked at both of those pictures and I am unsure which part was the whole hub assembly. Its possible it would be number 8 on there as that looks like it is the entire wheel and bearings. Again I am showing how much I need to learn about these.
I appreciate your assistance for this part.
Update: Ok, So I have been looking around and reading some other posts, they mentioned a site called http://www.china-parts.co.uk/ and I think I may have found the part that seems to match fairly well.
Rear Wheel Hub - CG Ref: WH008004
Currently they are out of stock.
Old 07-09-2015, 01:00 AM   #6
Welcome!
What type of bike do you have? Street? Dual Sport? Dirt?
Old 07-09-2015, 02:12 AM   #7
Thank you for the welcome.
The bike is a Hi-Bird QH-125-10. I think its a street only bike. On the hi-bird site it shows something completely different that what I have. Mine is more like a scooter type with the gas tank under the seat. It looks like the one in the thread here. http://chinariders.net/showthread.ph...hlight=Hi-bird. Going to the Honda dealer tomorrow to see if they have something that would help.
Old 07-09-2015, 02:23 AM   #8
Those are neat machines; the remind me of the old Honda Cub.
Be careful going into the dealer. As soon as they learn it is a China bike, they'll likely give you the silent treatment.
Old 07-27-2015, 06:45 PM   #9
ok so I purchased a Honda CT90K1 Trail 90 Rear sprocket hub from ebay since it most closely matched in specs the one that had broken and it came with a 45 tooth rear sprocket. The original sprocket is a 42 tooth. What would be the difference if I used the 45 rear instead of the 42. I am not sure what is on the front as of yet since I have not opened that hatch at this time.
Old 07-27-2015, 07:04 PM   #10
katoranger's Avatar
The 45 will be a little lower geared. Depending on the front sprocket you may find that you need to shift earlier and loose alittle top speed.
Old 07-27-2015, 07:23 PM   #11
that makes sense. I will see if I can get the 42 on there and see what the front is. Thank you for the info.
Old 07-27-2015, 08:56 PM   #12
Without changing anything else, the 45 tooth rear will help you accelerate more quickly.
Old 07-27-2015, 09:49 PM   #13
Is there a way to get that acceleration and also keep a good top end? The top end on the bike I have is pretty low already, supposed to be around 65 but more like 40 to 45. I am still attempting to get information on gearing for the bike. Ascot500 is the only other user I have seen with the exact bike I have.
Old 07-28-2015, 10:39 AM   #14
You can keep playing with gearing until you find the sweet spot. Use math to determine the ratio you're working with, and then move the ratio up or down, according to your needs. You can also look at JT's chart here: http://www.jtsprockets.com/fileadmin...tgearratio.pdf
Once you have the acceleration and top speed you can work with (it's always a balance), the next step would be "stage one mods" to help the bike breathe better and flow a little more fuel to compensate.
Old 08-25-2015, 03:24 PM   #15
Ascot500   Ascot500 is offline
Chuck, I no longer have my QH-125, but I do have some sprockets left
Ping me if you still need them
Ascot500@hotmail.com
hi-bird, qh-125-10
Search this Thread:
Advanced Search
Display Modes
