Old 06-11-2015, 02:12 PM   #1
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
New UK Skyteam V-Raptor 250 - Laser Tag
In another post, I mentioned you could get a lazer pointer that projected a red line when you applied the brakes. I couldn't resist and bought it from eBay.
Today, after dealing with all of the emails and projects I have on the go, I manged to finish by 1400 so took the bike out for a nice 30 mile ride along the back roads. The engine is definitely freeing up and it pulled up to 50 mph without seeming to work too hard. I think it is going to need a sproket change at some point in the future as I was running out of gears - a common problem on dual use bikes - but that is for another day.
Feeling enthused, I got the laser pointer out and looked to see how hard it was going to be to fit.
Unwrapping. It is about 1/2 inch diameter and 3/4 inch long
The front twists to align the beam, not obvious, I thought I had a wobbly one.
Looking up under the fender, I found the wiring for the rear light - here you can see where I temporarily wired the laser into the circuit to check it.
Here you can see where I placed it to see how well I could get the beam to display
This is it mounted on top of the rear light unit. It is stuck with 3M double sided tape and I drilled a 1mm hole through and inserted a couple of self tappers.
Here is the beam. It was very sunny today and the beam can be seen about 6 ft aft of the bike.
I tucked all of the wiring away and cable tied everything securely. There is a little box about a 1/2 inch square in the wiring of the light so it wasnt possible to simply drill a small hole to feed the wire through so that is tucked up within the light support.
I will try and get some photos when it is dark.
Jeff
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 06-12-2015, 12:18 AM   #2
Is the purpose to attract the attention of cagers?
Old 06-12-2015, 01:06 AM   #3
Is this a James Bond, 007 device which blinds following motorists, who are preferably bad guys?
Old 06-12-2015, 06:29 AM   #4
JTHSPACE's Avatar
I am simply offering Laser Eye Surgery to motorists who drive too close. I see it as a public service as I am not charging them for it.
Old 06-12-2015, 08:06 AM   #5
Search this Thread:
Advanced Search
Display Modes
