Old 06-30-2013, 06:42 PM   #226
If the regulator/rectifier is good, and the wiring is good, then you shouldn't blow a new flasher relay. However, if you don't need to install one, save the money.
Old 07-05-2013, 07:04 AM   #227
Corvairkid   Corvairkid is offline
Corvairkid's Avatar
so back to the zong i cant get it to idle and accelerate right what am i missing this time i wonder.... it will rev up then bog out like its draining the carb of fuel but not filling up
Old 07-05-2013, 08:12 AM   #228
Check the needle valve in the carburetor bowl.
Old 07-05-2013, 08:45 AM   #229
Corvairkid's Avatar
its clean and operating properly as far as i can tell ill pull it and see it the floats are properly adjusted maybe there to low....
Old 07-05-2013, 11:29 AM   #230
katoranger's Avatar
Make sure the tank is venting too. Try opening the fuel cap and see if it gets better.
Old 07-05-2013, 08:45 PM   #231
Corvairkid's Avatar
well i found a broken spring in the choke...... i wonder if that was the problem.... i also got a bigger hose for the fuel.... got a lot of rust powder out of the filter in the petcock valve as well...... arg it never ends
Old 07-05-2013, 08:46 PM   #232
Corvairkid's Avatar
plenty of venting with the gas cap open....
Old 08-06-2014, 09:53 AM   #233
zs250gs   zs250gs is offline
hi,
do you know, any other compatible cdi unit for zs250 gs? it is reaaly diffucult to find this 002.
thanks.
Old 08-06-2014, 11:07 AM   #234
humanbeing's Avatar
It's a big bored Yammie.
http://chinariders.net/showthread.php?t=13934
That CDI is AC or DC?
If have money to burn, u can re-wire it as Yammie.
Old 08-06-2014, 11:25 AM   #235
Originally Posted by zs250gs View Post
hi,
thanks.
Do you live in the United States? Can you post a photograph of your CDI unit? Does the CDI unit have any writing on it?
Search this Thread:
Advanced Search
Display Modes
