Old 04-14-2024, 05:32 AM   #76
artur94   artur94 is offline
Hi all I have a question about the Rocker arms Pins orientation. I had to do service of top end of my bike engine as one of the baring has fail on the camshaft, lucky, I have stop using the bike immediately when start hearing some ode noises in the engine. I did replace the rocker arms with pins but now I am not sure if I have installed the pins correctly… Where should be the flat spot of Pins orientated – UP towards petrol tank or Down towards ground? Thanks for Help
Old 05-06-2024, 08:20 AM   #77
I will answer my self on the above question about orientation of Rocker arms pins.
First I have whach all videos on YouTube and on one I have spotted the correct orientation:
CSC RX3 Engine teardown by Sifu Carlos
Second I have asked CSC directly and after some time I have get answer:
"The flat spot faces up and the 2 little oil holes face down."
So I have asemble the bike and tested for 2 weeks already and can confirm that the above is correct
All the best for everyone
