Old 03-26-2024, 08:56 PM   #16
Originally Posted by Weresquatch View Post
That's just in need of some more persuading.
I may take another look at it over the weekend
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 03-27-2024, 12:58 PM   #17
You were completely correct. Put a piece of 2x4 against the insert to protect it and slammed a 20lb dumbbell against the wood a few times. Much better!
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 03-27-2024, 01:10 PM   #18
vividpixel's Avatar
Originally Posted by Aussie_in_MO View Post
Planning on making some extensions for the upper headlight mounts to move it into a more upright position and help with aiming at things that aren't the top of trees.
If you haven't already noticed and tried it, there is an adjustment screw below the headlight to aim the beam.
Templar X 250: 14t / 42t, Nibbi PE30
Old 03-27-2024, 01:39 PM   #19
Yep, first thing I tried the other week. Maxed out the adjustment but it was still pointing too high.
Wound up getting a nylon spacer, some washers, and longer screw. That got it pointed down far enough to work.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 03-28-2024, 01:39 PM   #20
Weresquatch   Weresquatch is online now
Weresquatch's Avatar
I didn't know that! Thank you.
Templar X 250
Vespa GTS 300
Vespa ET4 150
Triumph Legend TT 900
Old 04-05-2024, 12:39 PM   #21
Just got my Missouri title in the mail today. Took longer than normal but proof you can get a MO title (and tags) on a Templar X even if the MCO says "Off-road motorcycle"
My buddy in town just applied for his yesterday (same situation on the MCO), and they let it through as well.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Last edited by Aussie_in_MO; 04-06-2024 at 10:17 PM. Reason: clarified - titled AND tagged/registered
Old 04-05-2024, 12:56 PM   #22
Just got my Missouri title in the mail today. Took longer than normal but proof you can get a MO title on a Templar X even if the MCO says "Off-road motorcycle"
Title? yes- MCO and bill of sale will get you a MO title. But plates? Did you get it registered for road use?
As I understand it, it must say motorcycle in the "vehicle type" field on the MCO to get it plated/registered for the road.
MO also wants proof of financial responsibility (insurance) and receipts from personal property tax for the past two years for plates/registration.
Old 04-05-2024, 01:08 PM   #23
Both mine and my buddy's are plated in MO, yes.
I've been licensing vehicles in MO for years so I do know what is required in terms of Insurance and personal property tax info.
I got a safety inspection just to make sure I didn't have to go back to the DMV if they bounced me. They didn't even want to see the paperwork because it was a brand new bike and considered exempt from inspection for the first 10 years or 150,000mi (https://dor.mo.gov/motor-vehicle/add...resources.html).
My buddy did not get an inspection at all, they ran the application and handed him a plate.
It all depends on the mood of the clerk at the DMV office. I was expecting to get rejected for plates without the inspection because of the MCO but apparently Ozark, MO license office doesn't care.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 04-05-2024, 05:09 PM   #24
Wow. This is proof that they are all different. No way in KC area
Old 04-05-2024, 07:20 PM   #25
Out and about this evening with my buddy.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 04-07-2024, 10:24 PM   #26
35 miles of forestry roads today.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 04-16-2024, 09:58 PM   #27
Minor update, finally got around to taking pics of my headlight modification.
I had some pre-drilled stainless strap laying around, pretty sure it was in the hardware kit for a basketball goal I put up recently, that I used to tilt the top of the headlight plate forward so I could adjust the headlight better.
Used the factory bolts plus some of the ones from the shipping crate to install.
Much better! Headlight isn't pointing off into the top of trees any more.
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 04-17-2024, 06:17 PM   #28
K'hermiit   K'hermiit is offline
K'hermiit's Avatar
That is essentially what I did to mine. Makes the key a lot easier to access as well.
Old 04-17-2024, 07:27 PM   #29
I solved the key problem on day one by trimming the round part off so it's more like a regular bike key.
I think I may have enough room between the dash and headlight plate to store a small toolkit now though
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
Old 04-19-2024, 06:13 PM   #30
Great way to kick off the weekend!
2023 Templar X
1976 Yamaha DT175
1974 Honda MT125
