Old 01-20-2024, 01:39 PM   #1
AJPMike   AJPMike is offline
CG250 with reverse
I'm interested in using a CG250 engine with reverse on an ATV project. I noticed that reverse is typically where 1st gear would be (R-N-1-2-3-4). Would it be possible to accidently go into reverse while moving forward? Are there any disadvantages to using this engine over the 5 spd dirt bike engine?
AJPMike
Old 01-20-2024, 01:58 PM   #2
Bruces   Bruces is online now
Yes you can hit reverse while moving foreward ,scary on a dirt bike ,that’s all the disadvantage you need to know if you are putting it in a dirt bike .They are usually electric start only.I put one in an xr200 frame,no good so swapped it out for a bike engine
Old 01-21-2024, 05:18 AM   #3
Mudflap   Mudflap is offline
Unlike a normal motorcycle engine where you can shift past neutral, in an ATV engine it takes 2 clicks of the gear lever to get from 1st to reverse or reverse to first.
Old 01-21-2024, 08:35 AM   #4
One click after 4th with the common circular shift pattern and you are in reverse hell .
Old 01-21-2024, 04:34 PM   #5
Are you saying you can shift past 4th gear and end up in reverse?
Old 01-21-2024, 06:14 PM   #6
Yes if you have the circular shift pattern .
Old 01-22-2024, 06:45 AM   #7
I've never heard of a CG engine with reverse that also has a circular shift pattern. It wouldn't make sense.
Old 01-22-2024, 07:46 AM   #8
I have had 4-5 come through my shop ,all the same make and model ,I don’t do much Chinese atv work and I no longer work on those particular machines as they are garbage by the time I see them .I agree ,they do not make sense ,actually any circular shift pattern bike are a dumb idea as well ,but they are out there unfortunately .
Old 01-22-2024, 08:44 AM   #9
I own a 2018 Taotao Rhino with a CG engine that is approaching 3000 hours with zero engine issues. It has only had oil changes and valve adjustments and a new spark plug. I used to have a Taotao ATA250d that I bought used that also had zero engine issues. Very reliable engines. Both have reverse gear.
Old 01-22-2024, 09:27 AM   #10
I think I will get one for my project. I can live with the shift pattern. I was just concerned that you could hit reverse accidently but I don’t think it will be a problem. Thanks for the help.
Mike
Old 01-22-2024, 09:36 AM   #11
dirtbkr188's Avatar
Many years ago, my wife had a Bridgestone 175 Hurricane Scrambler, that had a dual shift pattern, it was either conventional, or rotary, depending upon which you selected.
The pics are not of her bike, it was a bike that was sold at auction last November.
