Old 10-08-2023, 07:36 PM   #31
Zapkin   Zapkin is offline
Zapkin's Avatar
also found a little lake.
ID:	30154   Click image for larger version
2022 Hawk 250
Old 10-08-2023, 07:39 PM   #32
Zapkin's Avatar
Originally Posted by XLsior View Post
is the leak impacting the oil level significantly and or causing smoke/burnoff...If not it can be 'lived with' for a while...
No harm in replacing the head gasket/oil feed o'ring as you don't have to replace the cylinder and piston.
Hopefully you already have a torque wrench for the head bolts...
I posted a picture of it when I first discovered it. Since then I've washed the oil off, but it's still leaking. It's a super slow leak so far, but it's going to knag at me until I fix it.
I just had to ride today, the weather was good for it and the trees are changing and my brain was being calm. So had to do it.
2022 Hawk 250
Old 10-08-2023, 09:20 PM   #33
XLsior   XLsior is online now
XLsior's Avatar
Ok i just looked at the leak photo...its on the pushrod drain back side not the pressurized oil feed side...
which means the valves and rockers are still getting oil.
Though the leak is somewhat significant so you're on right path to repair...
Remember to backoff the valve adjustment screws prior to removing the 3 valve rocker assembly bolts..
As far as torque setting somewhere around 25ft pounds and under 30ft pounds...I say this as my particular torque wrench is a bit vague at the lower adjustment settings.
I go around krisskross/star pattern with 20ft pounds then adjust up to the 25ft* and do another round of tightening.
Also don't forget the washers...
4 inner head stud bolts and the 5th outer bolt witch locks into the cam follower shaft.
Old 10-09-2023, 01:10 AM   #34
Zapkin's Avatar
thanks guys. I will review all of this right before tearing into it. I think I got this. its fun. i mean, say what you want..its fun to wrench on these bikes.
2022 Hawk 250
Old 10-09-2023, 02:28 PM   #35
bigdano711's Avatar
Originally Posted by Zapkin View Post
I bought a torque wrench and learned how to use it. I rode two hours today with no issues, but like I said I have to remove the tank to do the speedometer so I might as well do it all at the same time. Anyway, I rode out to two covered bridges (I don't really like them that much but they are a great excuse to get rural). here are a few pictures.
What a cool place for a "safety meeting". ;-)
Old 10-10-2023, 09:35 AM   #36
Zapkin's Avatar
Yes.. and Yes i did. and remember "safety is #1 priority"
2022 Hawk 250
Old 10-29-2023, 06:21 PM   #37
Zapkin's Avatar
Not sure if there is an interest. The current state of the hawk is this. running. occasional oil smell. almost 6000 units boys! really the only issues I've had with the bike are issues I created myself by being a newb and trying to fix stuff that wasn't broken.
2022 Hawk 250
Old 10-29-2023, 06:50 PM   #38
buzz   buzz is offline
Thats part of the fun. let the madness go on.
Old 11-18-2023, 06:42 PM   #39
Zapkin's Avatar
Current state of the Hawk
Took her out to Turkey Run Dam and took some pictures, made a video and did a perimeter search for evidence of Bigfoot.
2022 Hawk 250
Old 11-18-2023, 06:46 PM   #40
Zapkin's Avatar
2022 Hawk 250
Old 11-18-2023, 07:27 PM   #41
Citizens Arrest!! Citizens Arrest!!! Can't you see ? It clearly says NOT to park in front of the gate ?
Old 12-01-2023, 10:04 AM   #42
Zapkin's Avatar
All i bought the Hawk for Christmas was a handlebar riser. I expect to be able to gain an additional 1.0 to 1.25 mph with this on the bike. I don't know why, but I do.
2022 Hawk 250
Old 12-01-2023, 04:29 PM   #43
Do©Hawk   Do©Hawk is offline
Might need to start a covered bridge thread. I have a couple within riding distance of my location.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 12-01-2023, 04:54 PM   #44
Me too,theres a few around here.
Old 12-01-2023, 05:20 PM   #45
flopsweat   flopsweat is offline
flopsweat's Avatar
Oh I know of at least one, if not too. Cheesy is about an hour closer to it than I, but I would 100% make a day out of getting that one photo for this one thread on this one forum.
2021 CSC TT250
