Old 04-17-2022, 01:31 AM   #1
Fletchman919   Fletchman919 is offline
Question Need help finding parts (Apollo??) Orion AGB 30D 250cc
I bought the bike today, but I can't seem to find who sells parts for it. It's a 2007 model and I need quite a few miscellaneous parts. Front brake assembly, petcock, chain adjusters, air filter, rear wheel bearings. Any help would be greatly appreciated!
On another note, the bike will not open up all the way. I suspect a carb issue, but is it possible that it has a rev limiter built into the CDI?
Old 04-17-2022, 07:09 AM   #2
buzz   buzz is offline
Hello Its the carburetor,trust me. This new gas sucks,causes a lot of problems. Bet carb needs bigger jets,and a good cleaning. Best of luck.
Old 04-17-2022, 12:07 PM   #3
It's a 2007. She needs a go-thru just to clean everything out. Odds are the pilot jet is clogged and there's probably gunk in the float bowl.
Regarding parts, with China bikes, many can be found on EBay or Amazon. Type in something broad like "Chinese dirt bike front brake assembly" and stuff like this comes up. You can't necessarily ask for Apollo parts, in specific.
https://www.amazon.com/Cylinder-Cali...s%2C243&sr=8-2
Regarding things like wheel bearings, you just need to dig in and look for a part# on the grease seal or if none available, caliper it out and find it online. Owning a China bike requires a little more digging but it's all out there for cheap.
Old 04-18-2022, 12:42 AM   #4
Ok thank you guys!
baja, lifan, roketa, tao tao, zongshen
