Old 12-22-2020, 07:44 PM   #1
miatawnt2b   miatawnt2b is offline
santa clause is coming to town and he needs help
The wife and I decided to shake down the 3 new 125's this afternoon. One of them just quit as she was going up a hill. Refuses to restart.
I haven't completely torn into it, but I've swapped a carb, spark plug and coil so far. All the parts from the dead ATV work fine on the good one.
On the dead ATV, I have spark and fuel flow, i've verified spark stops when you pull the emergency disconnect button. So I think the electrics are working, I'm wondering if it could have gotten out of time somehow.
Please, any help would be appreciated. I'm in a bind.
-J
Old 12-23-2020, 07:40 AM   #2
More than likely it's a bad CDI. Try swapping one with the other to rule that out.
2020 Kawasaki Vulcan S
Old 12-23-2020, 09:33 AM   #3
TxTaoRider   TxTaoRider is offline
Or try swapping the suspect cdi box on to a running atv.
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 12-23-2020, 09:54 AM   #4
yep. swapped the regulator and the CDI from the dead quad into a working one. Fired right up. Put the ones from the ones from the good quad into the dead quad and still won't start. The only thing I haven't swapped is the engine at this point right?
Old 12-23-2020, 10:08 AM   #5
You might need to adjust the valves on the one not running. It's possible that the valves are set so tight that the valves are not fully seated which equals no compression. This is common on just about all the china bikes and atv's.
Old 12-23-2020, 11:06 AM   #6
yea, tried that also just now. They were indeed tight. same behavior though. Strange though that it was running perfect then just died without any notice. I'm leaning magneto (even though i have spark, who knows if its in time), but I really don't want to tear into it that deep without talking to the dealer first.
This is a real bummer.
-J
Old 12-23-2020, 11:13 AM   #7
is it possible to pull the magneto cover without taking the engine completely out on a 125?
Old 12-23-2020, 11:15 AM   #8
Did you check compression?
Also Someone else on here had an issue with the pick up sensor being set to far away. It still had spark but was weak. May be something to look into.
Old 12-23-2020, 11:34 AM   #9
One thing I don't have is a compression gauge. I can feel pretty good puffs of air out the pipe.
Old 12-23-2020, 11:49 AM   #10
Coil partial grounding on paint
Old 12-23-2020, 12:19 PM   #11
coil is all plastic and just hanging there at the moment. not touching anything.
Old 12-23-2020, 02:54 PM   #12
Sounds like it does not ground by contact with the frame. Alot of the bikes, the coil is metal and grounds against the frame by mounting bolts, paint underlying can make for bad ground which will cause the weak spark.
Old 12-23-2020, 03:06 PM   #13
Thanks for all your help guys. I really appreciate it. No luck yet, but hopefully I'll get it.
-J
Old 12-23-2020, 03:37 PM   #14
swapped out the stator and pickup assembly from a good quad and still nothing.
Old 12-23-2020, 03:42 PM   #15
Is the spark plug wet?
