02-20-2020, 12:27 PM | #31 |
i agree, but will have to be later on. capped out in the pocket book.
i dont know squat about fuel injection, so i am a bit cautious about changing exhaust and not mess up the computer efi. if engineered properly it should self adjust but no one has actually done it yet on this generation 2 motor. wish they have so i would know 100% no issues |
02-20-2020, 12:44 PM | #32 |
The ECU will adjust to the changes in the exhaust.
02-20-2020, 12:52 PM | #33 |
automatically or is there a boot sequence restart ecu thingy?
i am extremely cautious here on changing any intake or exhaust on fi, but i will ride it stock for a while. and this second gen motor have some sort of turbocharging on it? |
02-20-2020, 01:01 PM | #34 | |
02-20-2020, 01:37 PM | #35 |
some sort of turbocharging?i read this
"Another advantage about KPM-200 is the 200cc NBF GENERATION II Engine, which adopts turbocharging, crankshaft displacement, roller valve rocker arm, piston spray and other core technologies. It exerts high compression ratio of 11:1, with the max power up to 12.5kw and max torque 17n.m."
02-20-2020, 01:47 PM | #36 |
I'm not sure what they are talking about but there definitely no turbocharger on your bike. But sounds real impressive. lol
02-20-2020, 01:50 PM | #37 | |
.................................................. ........... i was comparing this to the cb200 specs. pretty similar comparison. you know each being 17hp and top speed 77mph.... duel carb vs efi... as you can see, i am gettin a lot of work done today. https://www.motorcyclespecs.co.za/mo...onda_cb200.htm |
02-20-2020, 01:52 PM | #38 | |
HAHA! That CB200 was my first bike I owned. Same color too (Green).
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 02-20-2020 at 02:47 PM. |
02-20-2020, 09:02 PM | #39 | |
Awesome looking bike, by the way. What was the delivered price?
02-21-2020, 09:09 PM | #42 |
license plate mount
the holes werent matching up so i drilled new ones at 2 1/4" apart to fit on existing bolts from removing the fender. the bolts are attached to metal and is sturdy enough to support a plate hanger.
$8 plate mount: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 $6 lights and bolts for holding the plate on the mount all in one. i love these and have used them many times: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
02-21-2020, 09:26 PM | #44 |
a peek inside while putting the battery in
and rubber inserts to fill the holes where the other location for mirrors would be used. nice touch lifan, those holes were hideous. again took me a while to find out where they went....
btw when i hooked up the battery i noticed the headlights dont come on automatically nor with the high beam switch the passing flasher button did make them turn on. i assume the headlights only turn on when it is started and wont know until tomorrow. |
02-22-2020, 01:31 PM | #45 |
stock sprockets 16t 49t
