Old 12-15-2018, 07:30 PM   #1
BBOWL10   BBOWL10 is offline
BBOWL10's Avatar
Hawk 250 Bulbs
Does anyone know what type of turn signal and brake light bulbs the Hawk takes? I would like to have a couple of spares handy. The manual doesn't specify. Thanks!
Old 12-15-2018, 10:49 PM   #2
The original rear tail/Brake is a 2057, which is a low power version of an 1157. I have an LED 1157 in mine.
Originial turn signal bulbs are 5008 miniature socket style bulbs.
Old 12-16-2018, 02:01 AM   #3
I just pulled one out and let the autozone tech worry about the rest lol.
Old 12-16-2018, 07:58 AM   #4
BBOWL10's Avatar
Thanks!
Old 12-16-2018, 08:57 AM   #5
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Has anyone installed LED turn signals drop in? No blink issues?
The reason I ask is I see an adjustable box sold to help the voltage work the blink rate correctly. Was hesitant to get bulbs to have to get a box to make it work right.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 12-16-2018, 10:15 AM   #6
Azhule   Azhule is offline
You can always change out the Rear Turn Signal Bulbs to LED leaving the front bulbs stock... doing this the combination of bulbs usually uses plenty of juice for the stock flasher relay to work properly.
Old 12-16-2018, 10:16 AM   #7
BBOWL10's Avatar
You will probably have to install resistors.
Old 12-16-2018, 11:55 AM   #8
NzBrakelathes's Avatar
Just change the flasher can to LED style which is electronic rather then Bimetal strip type
Old 12-22-2018, 06:41 AM   #9
BBOWL10's Avatar
License Plate Bulb
How about that little license plate light? I appears to be a type of push in bulb. I would like to put an LED in there. I think there is one in the headlight reflector to for some kind of DRL set up.
Old 12-22-2018, 01:36 PM   #10
Red Hawk's Avatar
You'd be better off clipping the DTR light in the head light and pulling the positive to a USB port adapter box.
Then your USB is on ignition and headlight switch so you don't kill the battery. My USB saved my SENA on a long ride. Coms are awesome when you ride together.
Old 12-22-2018, 01:49 PM   #11
BBOWL10's Avatar
That's not a bad idea! I would still like to replace the license plate lamp with an LED.
Old 12-22-2018, 04:51 PM   #12
Fantastic Moto   Fantastic Moto is offline
Fantastic Moto's Avatar
If you are thinking about putting a led headlight in I made a YouTube video of putting a led headlight in.
Here is the link :
Fantastic Moto
2017 Coolster Pit Bike (SOLD)
2015 Green Hawk(Air box opened,Alarm Disabled, China Mikunni carb,105 main jet) (SOLD)
2018 Black Hawk(Air Box opened, Alarm Disabled,China Mikunni Carb,110 Main Jet,Cut out Cat,)
When Life Gets You Down, Remember it's one down the rest are all up.
Check me out on YouTube:https://www.youtube.com/channel/UCKu...EEviZ7IjMmLlEw
Old 12-22-2018, 09:51 PM   #13
BBOWL10's Avatar
Originally Posted by black mamba View Post
if you are thinking about putting a led headlight in i made a youtube video of putting a led headlight in.
Here is the link :
thx!
Old 04-15-2024, 02:45 AM   #14
Egandp   Egandp is offline
1157 for turn signal too
