Old 06-27-2016, 06:48 PM   #1
CDryder   CDryder is offline
Hello from Iowa!
Hi everyone, I'm a 19 year old guy from Iowa who is mostly new to motorcycles. Right now I'm riding an rps hawk and looking forward to getting a csc tt250 in the next few weeks. I only just finished assembly of the hawk yesterday but it seems like a great bike so far.
As a new rider I do have a question:
I haven't adjusted the carburetor yet and the bike won't idle, so when I was riding I gave too little gas and accidentally killed the engine while in 1st or 2nd gear. This caused the rear wheel to seemingly lock up and caused me to slide a bit until I stopped on the gravel.
Is this normal for motorcycles when the engine dies in low gear? I wouldn't think it would happen if I was going faster in a higher gear, but it's not something I'd like to test out...
Old 06-27-2016, 07:06 PM   #2
just find the idle adjust screw and turn it up, right?
Old 06-27-2016, 07:24 PM   #3
I thought I needed to do something like that, but I haven't had the chance to check for the screw yet. I'll have to look at the bike later.
Aside from the idle issue, the rear wheel locking when the engine dies is normal? I figured it should roll to a stop.
Old 06-27-2016, 08:19 PM   #4
hertz9753's Avatar
You are a first time four stroke rider. It is normal for the rear wheel to do that. It's called engine compression braking.
Old 06-27-2016, 08:57 PM   #5
I had it happen to me upon clutch release in second gear, it's called clean your drawers.
Old 06-27-2016, 09:13 PM   #6
hertz9753's Avatar
It's a common problem for two stroke riders getting on a four stroke for the first time. Going from a four stroke to a two stroke is also scary with out that third brake in the first dirt corner.
Old 06-28-2016, 12:28 PM   #7
Welcome!
At the risk of sounding like your Dad, please take a MSF course; it'll teach you terrific skills for the road.
Turning the idle up might only be a Band-Aid. If the slow jet is too small, it'll continue to give you trouble, especially in colder weather.
Old 06-28-2016, 08:11 PM   #8
Yep, the only prior motorcycle experience I've had was on a little 2 stroke Yamaha rt 100 when I was younger. That bike never seemed to lock up to my memory which made me question this one.
Right now I'm just riding the hawk as a dirtbike. It's actually my brother's bike and he will likely keep using it mostly on dirt. He's letting me use it a bit to get practice until the tt250 arrives. I've discovered I'm not that great at riding yet and I can take an MSF course close to home so I'll probably sign up.
Thanks for all the help!
Old 06-28-2016, 09:47 PM   #9
dpl096   dpl096 is offline
dpl096's Avatar
Welcome aboard. Congratulations on the Hawk and the upcoming TT...... Ride safe, be smart and have fun.....oh and big time ditto to Weld...the class is a good idea.
― Thomas Jefferson
Old 06-29-2016, 12:48 AM   #10
hertz9753's Avatar
When I did the MS a few years ago (1981) we had Yamaha DT100 Honda Twinstar 185 bikes. I always got a DT 100. I was a big boy on a tiny bike when I was 14.
Old 06-29-2016, 04:16 AM   #11
SeerAtlas   SeerAtlas is offline
Thumbs Up
welcome to the board there is a ton of good info on tuning up a hawk here and soon to be pretty much everything you ever wanted to know about the tt250. use that search engine
I too am awaiting my imminent tt250 by the way, what color did you order? he,he,he
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking
Old 06-29-2016, 10:16 AM   #12
zingshoen   zingshoen is offline
zingshoen's Avatar
greetings to iowa! that locking means that you have good compression ie the motor stops the rear wheel from turning. if you don t want the wheel to lock up you need to pull the clutch.
you ll work out how the bike behaves, but you need a reliable ride to begin with. getting a steady idle is a good start, and you ll find posts here on how to do it.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 06-29-2016, 09:39 PM   #13
As someone who is 6' 3", I quickly became too tall for the rt 100. I actually rode a friend's old pw50 once as a joke...I'm not sure who had more fun, me or the people watching.
I've been following some threads here very closely which has been very helpful. Also I was going to purchase the tt250 in black, but I decided on white since it's the fastest color.
