Old 02-14-2016, 08:46 PM   #16
maverickfe   maverickfe is offline
ok I took it apart and found that the main jet is #102 and the slow jet is #35 .
Old 02-14-2016, 09:35 PM   #17
humanbeing's Avatar
PTG vs PZ http://translate.google.com/translat...3D1&edit-text=
Old 02-14-2016, 11:11 PM   #18
I'd jump a couple of sizes to around 40 for the slow jet.
Old 02-14-2016, 11:28 PM   #19
Weldangrind Should I change where the needle is at ? Right now it on the top one.
Old 02-18-2016, 04:19 PM   #20
Well I have the main and slow jets coming main is a 108 and the slow 40 .SMC still makes this atv but it's sold in England and Germany under the name Barossa.
Old 02-22-2016, 09:26 PM   #21
Not yet. Try to only make one change at a time. If the bike starts and idles well, and goes well at WOT but has a flat spot at mid-range, then move the clip. When you do, move it only one notch and re-test.
Old 02-22-2016, 11:06 PM   #22
Thanks Weldangrind for the info. Well after putting new low and main jets in its running now wow. Now I have to adjust the valves to get the noise ( ticking )gone. So thinks for everyone that helped out.
Old 02-22-2016, 11:29 PM   #23
Some pictures of the motor.
Old 02-23-2016, 12:13 AM   #24
That's an interesting motor design.
Don't try to make the valves quiet; that's asking for trouble. As Spud says, slappy valves are happy valves.
Old 02-23-2016, 05:10 AM   #25
humanbeing's Avatar
That's an interesting motor design...
Striped http://ku-motor.blogspot.com/2014/08/honda-ca250.html
Old 03-10-2016, 04:42 PM   #26
Well everything is ok so far. It's running great now don't have to use the choke at all now one push of the button and it starts right up. So just putting the new body parts on it now the only thing is that the new head light is a 4 plug and the old one is 3. Has a small lamp with the main one.so trying to fix that one.
Thanks for all the help too...
