Old 07-25-2015, 05:50 AM   #16
cheesy   cheesy is offline
cheesy's Avatar
I've used Seal-All on external fuel leaks and it does a good job. Not sure how long it would last immersed, tho. The added weight of whatever you use on the float MAY make it tougher to set the level. Might be wise just to replace them.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-25-2015, 08:49 AM   #17
Dave_D   Dave_D is offline
Dave_D's Avatar
That's good to know weld I'll look into a couple different products.
And cheesy I know it will ad weight. I'll just reset all the floats after there repaired.
I just want to get it running as cheep as possible right now.
Maybe replace them after I decide what my plan actually is.
If papers come back I'll either keep if for myself or sell it.
If no papers. Maybe a buggy project lol we'll see
Dave
Old 07-25-2015, 10:33 AM   #18
I used Permatex Cold Weld to repair the float stand-offs in my old TS250. The fuel that was left in the bowl for decades literally dissolved one of the stand-offs, so I built a new one out of Cold Weld and then filed it to shape. After it was formed, I used the hole in the other stand-off as a guide and drilled the float pin hole. It has worked ever since.
If you apply Cold Weld (or whatever) to one side of the floats to repair a hole, try to add a similar amount to the other float in the same spot, in an attempt to balance it. Use as little as possible.
