Old 08-09-2011, 11:05 AM   #1
yasting   yasting is offline
My Rebel T3 start but stalls at idle
When i start my Rebel T3, i need to give the engine a gas by hold the throttle. If i release gas, my Rebel stall.
I check my battery voltage is 12.44 volt,
I charge the battery with an external charger and with jumper cables,
I verify my choke,
I change CDI,
I change carburator,
I verify my gas filter and gas lines,
I check if i have spark on my spark plug and it's Ok,
And sometimes he doesn't start until i use jumper cablers.
Old 08-09-2011, 12:04 PM   #2
It sounds like the slow jet might be a little small for your needs. Remove the bowl from the old carb and unscrew the slow jet. Does it have a number on it?
Old 08-09-2011, 06:50 PM   #3
I have 25 slow jet on my mukini. But i don't think is a carburator problem because i try to replace the mukini carburator with my old stock carburator and i got the same problem.
Old 08-09-2011, 07:10 PM   #4
rotax583   rotax583 is offline
check the ignition switch.....I had a 110 do the same.if not make sur the gas lines are tight and that its not sucking air.
DEALER FOR ZSTAR,GIO,PITSTER PRO AND TAO TAO
Old 08-10-2011, 10:24 AM   #5
A T3 has a 200cc engine, correct? If so, a #25 slow jet would be a good choice. I'm now thinking that the slow jet is clogged. Can you see daylight through it?
Old 08-16-2011, 09:28 PM   #6
Yes I see daylight through my slow Jet, and i clean all my carburator without result. After i have replace my carburator with my stock carburator and it's a little bit easier to start but i need hold the trottle cable and i can't disengage the choke otherwise my atv stall.
Old 08-17-2011, 01:06 AM   #7
Does turning the pilot jet screw (air / fuel screw) have any result? If not, perhaps the pilot jet passage is clogged. Maybe there is some aluminum casting flash caught in there.
Old 08-17-2011, 08:49 AM   #8
I verify this and all is clean.
Old 08-17-2011, 09:48 AM   #9
TACyJAC1999   TACyJAC1999 is offline
Not to be a smart a#$, but did you adjust the idle speed screw..?
Old 08-17-2011, 10:18 AM   #10
That's an excellent question. I just transplanted a China motor into another bike, and the idle screw was the only step I had forgotten.
Old 08-17-2011, 02:52 PM   #11
Yes i check and recheck the pilot jet screw and the idle speed screw. I notice a little difference when i turn the idle screw, but the atv stall again and the rpm is unstable. Do you think the regulator can do this symptome.
Old 08-17-2011, 08:28 PM   #12
What regulator? I've never seen a fuel regulator on these machines, if that's what you mean.
Old 08-17-2011, 09:17 PM   #13
no a "Voltage Regulator Rectifier"
Old 08-17-2011, 09:22 PM   #14
check the intake valve,sounds like it could be tight
Old 08-18-2011, 09:55 AM   #15
How can I check the intake valve?
