Old 06-20-2022, 02:59 AM   #1
GamingRAPTRcom   GamingRAPTRcom is offline
GamingRAPTRcom's Avatar
Grin I've got the Lifan ECU Flasher Software for all Lifan ECU Models!!!
It supports full tuning of the ignition and fuel curves, so I looked up a local Dyno Tuning Company that brings their Dyno Trailer by events at Deals Gap. I've got an Aluminum Intake and Slip-On Stainless Steel Exhaust, so whatever they create for a fuel map should be universally usable for most Lifan X-Pects. If anyone else wants to build and share their ECU Tunes it'd be cool to see what we come up with. Anyways, here's the Lifan ECU Manual with the Free ECU Flashing Software.
https://t.me/GamingRAPTRcomTGE/3046
Also, here is the Lifan ECU Reflashing Software Guide along with the cables.
https://netcult.ch/elmue/HUD%20ECU%20Hacker/
Lifan to OBD2 Adapter Cable
https://www.amazon.com/dp/B08Y5YWRKH
Openport 2.0 ECU Reflashing Adapter
https://www.amazon.com/OpenPort-Tuni...dp/B09JLPW3QG/
Old 06-20-2022, 07:46 AM   #2
Thanks. I've downloaded the software. Now we in my world. I love tuning ECU's just to see how much power I can unleash. Now all I have to do is wait till my KPX250 arrives.
Direct link to Software: https://netcult.ch/elmue/HUD%20ECU%2...r/#Charityware
2020 Kawasaki Vulcan S
Old 06-20-2022, 05:45 PM   #3
Boatguy   Boatguy is offline
Boatguy's Avatar
Holy crap!!! This is amazing! Thank you for sharing.
Now do Evinrude etec motors! Lol
2020 Lifan x-pect
Old 06-21-2022, 09:02 AM   #4
Mudflap   Mudflap is offline
Wonder if this will work with the Lifan 168cc EFI scooter engine? May try it one of these days.
Old 06-21-2022, 09:16 AM   #5
If it uses the Lifan EFI 9 Euro 4 ECU then yes.
Old 03-06-2024, 05:29 PM   #6
dr99miller   dr99miller is offline
Jerry you've been a great resource since I bought my first China bike and found this forum, THANK YOU! You wouldn't happen to know if the KPM200 works on that ECU or not would you?
2021 Lifan KPM 200
2019 Venom BD578Z E-Vader
Old 06-21-2022, 12:51 PM   #7
JFOlivier   JFOlivier is offline
JFOlivier's Avatar
The only information I can find on my EFI is that is a HUNIER EFI 9.0 A200624. Google Hunier and you come up with nothing useful. I have ECU hacker and the interfaces required by have still to figure out how to use them. same with the Panlong bluetooth scanner. Does the Lifan EFI have a Lifan marking.
Old 06-21-2022, 01:45 PM   #8
Teklock   Teklock is offline
I do see where they added the 'Lifan EFI 9.0' xml to the newest version. Have you tried the newest version of hud ecu hacker? Which bike do you have?
I'm also wondering if you can change the mappings like you can with the MT05/05.2 ECU.
Old 06-21-2022, 03:12 PM   #9
JFOlivier's Avatar
Teklock, that Hunier EFI is on my 2020 Lifan X-pect. I downloaded ECU hacker about a month or so ago so guess it is the newest version, I have hooked the bike up to ECU hacker and chose the Lifan ECU and I connected and saw some information there but have not recorded anything so far. I have not figured the program out yet and don't really want to leave the bike idling too long while I play.
Old 06-21-2022, 04:58 PM   #10
You may need a J2534 compatible adapter like the Tactrix OpenPort adapter (or clone of it). The author of 'HUD ECU Hacker' is a member here. His name is Raptorix. Look up his posts for threads with a lot of good info.
Old 06-21-2022, 03:20 PM   #11
JFOlivier's Avatar
How do you down load the ECU flashing program ?
Old 06-21-2022, 04:23 PM   #12
It's towards the bottom of the page under Download and installation.
Old 06-22-2022, 09:41 AM   #13
JFOlivier's Avatar
Teklock, I have the VAG KKL adaptor which works fine. It is just that I do not know the program and its operation so hope to pick up bits and pieces as these threads continue.
John
Old 06-22-2022, 12:23 PM   #14
John
It does look like the x-pect has the 'Lifan EFI 9 Euro 4' as listed in hud ecu hacker. Can you select 'Download entire flash' and actually download it? I'm still a bit skeptical we can do this with this newer non-MT05 ecu.
Old 06-22-2022, 06:37 PM   #15
Thanks G-Raptr! I am sure these are leaned out upon arrival to get by import standards, and having no access to these adjustments is the main reason to go analog (carb). Getting into this is nothing short of game changer
ecu, flashing, lifan, tuner, x-pect
