06-06-2022, 11:42 PM | #1 |
New to me X22R
Howdy!
I picked up a 2019 X22R that needed some love. I replaced the cracked intake boot and put a pod filter on it (the air-box snorkel was missing). I have a jet kit inbound as it's running lean. It came with a carbon fiber muffler so that doesn't help with the lean condition I'm sure. It seems to run out of steam at about 65mph/6200 rpm. I know I need to get a smaller rear sprocket. I want to go 36 or 37 instead of the stock 42. Who sells a drop in sprocket, or does someone have the dimensions so I can get one custom made? Thanks! |
06-07-2022, 07:48 AM | #2 |
36 tooth will be the smallest you will want to go with without any issues.
Custom Sprockets https://shop.pbisprockets.com Center Hole Size. size: 64mm, 58mm if you remove the spacer ring - Size of bolt holes diameter. 10.5 circle diameter through center of all bolt holes: 96mm
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-07-2022 at 08:22 AM. |
06-11-2022, 10:40 PM | #3 |
Thanks,Jerry! That's what I was looking for.
I changed the jet today from 95 to 105, didn't run well so I switched to 100. Seems stronger but still runs out of steam at about the same rpm. I'll check the plug in the morning and see what gives. Think I'll try the 110. |
06-15-2022, 11:03 PM | #4 |
So I went straight to the 125 jet. The plug was black and fouled, way too rich. I decided to start over and put the original 95 back in it. The slow jet is 38. Runs good again but still starts surging at 6200 rpm. Is this normal?
06-15-2022, 11:18 PM | #5 |
When engine was stock it ran the best with a 105 main.
