09-23-2021, 01:13 PM | #1 |
taotao carb
hello, I have a TAO 125 quad the carburetor is flooding and it seems to be a good time to change the carburetor. Any recommendations?
09-23-2021, 02:17 PM | #2 |
PZ20.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 I've had this carb flood also. I pulled the bowl off and cleaned the float needle. I also set the float height. Took care of the issue. I would try this first before installing a new carb
09-23-2021, 02:44 PM | #3 |
carb
hello, the carb bowl is riveted on thought it was not serviceable?
09-23-2021, 03:36 PM | #4 |
Are you sure those are rivets, most are screws with no slot. A Dremmil tool with a cutoff wheel can be used to make a slot.
09-24-2021, 10:40 AM | #5 |
carb
I was looking at the carb with a dental mirror. I will have to take it off and check it out, I have a dremel. thanks
09-24-2021, 02:40 PM | #6 |
epa carb
YES those are screws witht he heads broke off... you can slot the heads to remove with screw driver,,, alittle work and be CARFULL... or buy a carb.. if you hav e the time and alittle skill .. then go but some screws to install... use premium fuel. then ALMOST no trouble...
