09-14-2021, 10:07 PM | #1 |
2021 Hawk DLX
I've got a major issue I got a 2021 hawk dlx 250. I rode it for 3 days it's got a 15 amp fuse in it as the main fuse every single time I turn the kill switch it'll run position I blow the fuse I have taken that bike apart followed every wire there is no bare wires it has a key switch plus a kill switch with the starter switch I have tried everything to figure out what these constant short is I finally come to the conclusion that it is my fuel pump shorting out. The reason I Come to this conclusion obviously since I can't feel it the fuel pump or anything cuz it blows a fuse instantly it's because when I was riding it the last time before all this started it started misfiring cutting out like it was starving for fuel or fire is anybody familiar with this it's brand new it's still under warranty but I'm second-guessing myself on the weather it is the fuel pump now since the Killswitch doesn't do anything with fuel I cannot figure it out any thoughts the only way I can get the dealer to check it out is send it all the way to Texas and I'm not doing that I live in Indiana has anybody had any issues it's the brand new bike any thoughts or any advice would be great it's been down for 6 days
09-14-2021, 10:10 PM | #2 |
It's got a connection to read the ECU but I do not have the machine to read the codes. Any advice or thoughts would be helpful in figuring this out on my own I have nothing more than a multimeter
09-14-2021, 10:14 PM | #3 |
1st off welcome to the site!
2nd, those are probably the longest two sentences ever written. Lol 3rd, it was a little hard to understand, but I'm sure someone here will know what the issue is and get you fixed up.
09-14-2021, 10:22 PM | #4 |
There's nothing wrong with the kill switch I took it completely apart I cannot figure out where my constant draw is at that is blowing the fuse if I have the the kill switch in the kill position you can turn the key on crank on the starter all you want but the minute you put the switch into the Run position it blows the fuse I took the Killswitch apart there's nothing wrong with it any advice
09-15-2021, 12:16 AM | #5 |
Issue with hawk 250
No one has had issues like this. I really wish someone could help I don't want to send the bike back but if I have to I will but if I do I'm not buying another one not from them they got the worst customer service ever seen in my life it's Moto Pro Joyce I can't get her answer me half the time I'm doing the work myself trying to save them money cuz I'm not letting them ship it but if I can't solve it then its no use to me please send feedback i know there are mechanics out there
09-15-2021, 07:40 AM | #6 |
Inspect all the wiring harness and look for shorts. You may have a bare wire shorting against the frame and grounding out.
09-15-2021, 09:19 AM | #7 |
If you're suspecting it's the fuel pump, try unplugging the fuel pump connector (go ahead and remove the tank so you can see everything), and then try to move your kill switch into position. If the fuse doesn't blow, you'll know you're barking up the right tree. If the fuse still blows, keep on removing items until you can run the kill switch without blowing the fuse. This is going to turn into a simple (but probably time consuming) process of elimination. There isn't a whole lot on these bikes that connects to electrical but you're just going to have to approach it methodically and take one piece of the puzzle out at a time. If you get all the components off and it still blows the fuse, then you know you have a wiring short to ground. The good news is that by that time, the whole bike will be pretty well stripped down and it'll make tracing the wiring a snap. If you really wanted to go for broke, you could get a small click-clack fuel pump from the auto parts store and hook that into a fuel can and try to run the bike off that as a step in your troubleshooting. Let us know how it works out for!
09-15-2021, 09:31 AM | #8 | |
Of course it won't help if you have a short on the harness side of the connector, so you might end up splitting the loom open to carefully inspect all the wiring if that's the case. |
09-18-2021, 10:44 AM | #10 |
Is it just the relay, or the fuel pump itself? It should be pretty simple to wire in a new relay if that's all it was. Should be an off-the-shelf part at any local auto supply store.
09-20-2021, 04:47 PM | #11 |
That's the thing I've went to every bike and auto place here 6 total. They have never seen a 4 post 30 Amp. They have only seen 5. I still have not received the part from moto pro. It has really been a pain in the butt. Not sure what to do
09-20-2021, 05:50 PM | #12 |
I did as Emerikol stated i unplugged the relay and it does not blow the fuse this was after i put the new pump in it. The relay also appears burnt. I know this is crazy cause the bike is still under their so called warranty but i needed it last week and do not have time for them shipping it back and forth. I just need to get it fixed. They are no help
09-20-2021, 05:57 PM | #13 |
punctuation
Yeah sorry not real good with punctuation. Seem to run everything together when aggravated. I do apologize
09-21-2021, 02:24 PM | #14 |
All I am at wits end. I put the new relay in today. The bike started right up so I thought the problem was fixed. I let it run for 5 minutes or so. I walked over to the bike went to rev it up a little and it blew the fuse instantly once again and now it is doing the exact same thing. It blows the fuse the minute i turn the key on with the kill switch in the run position. I dont even have time to engage the starter. How could the new relay have fixed it for 1 start and be doing the exact same thing all over again now with a new fuel pump and new relay.....please help I can not get any shop around here to look at it. I was diesel mechanic for 8 yrs in the service but I am not real wise on electrical. I thought I figured it out but apparently not. I am not sure what else to do other than bypass the kill switch but Im not sure how to do that since the starter switch is part of the kill switch and I am not even sure now if that is it. As i stated please help
09-21-2021, 04:38 PM | #15 | |
